Re: Anyone try aeromotive pump ?
[Re: VernMotor]
#1291872
08/26/12 08:33 PM
08/26/12 08:33 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Yes I used to run one a few years back and then ran the A2000 when I switched to ethanol.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: Thumperdart]
#1291879
08/26/12 10:54 PM
08/26/12 10:54 PM
Posts: 2,151 Fancy Farm Ky
wyoming
Fancy Farm Ky
I run that pump myself, had it on for I think 4 years, no problems, mine is deadheaded, I have a fuel pressure gauge and it show 7 pounds all the way thru the 1/4, it flows enough to run really low 10's for sure, and I belive quite a bit lower than that, allways seemed to me a lot of people go overkill on fuel pumps. Im feeding two edelbrook 800 cfm, and have also used the pump running two 750 Demons, didnt have a fuel issue with either setup.
[Re: wyoming]
#1291880
08/26/12 11:03 PM
08/26/12 11:03 PM
Posts: 6,295 U.S.
moparniac
U.S.
Mine is deadheaded! No issues at all!
But am going to return style setup now.
Mopar Performance
[Re: 572charger]
#1291886
08/27/12 09:25 AM
08/27/12 09:25 AM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
I keep forgetting to ask this, but do you have a transbrake, or are you still footbraking it, Jim?
[Re: VernMotor]
#1291890
08/27/12 05:10 PM
08/27/12 05:10 PM
Posts: 901 oh
julian2007
oh
whats wrong with your holley blue?
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: VernMotor]
#1291893
08/28/12 09:27 AM
08/28/12 09:27 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I ran the little 11203 Aeromotive pump for several years and went 9.50s at 140 mph at 3800# w/ it. I ran it deadheaded. That little pump works great. I moved up to the A1000 pump and a return style system a little over a year ago only b/c I started having vaporlocking issues in hot weather on pump gas. Runs no faster w/ the bigger system.
[Re: moparniac]
#1291894
08/30/12 03:51 PM
08/30/12 03:51 PM
Posts: 69 Fairhope, Alabama
BeeSuper
Fairhope, Alabama
I run that pump.
after much consideration trying to decide what pump to buy, I chose that pump too. I also got the return style regulator but have yet to install it, just collecting parts. Still trying to sort out the rest of the fuel system. Where should I mount the pump? Must I run a cell? Would it work if I mount pump above stock tank in trunk? Found a sender with a return line for the stock tank that would work. I want to keep my stock fuel guage but all the cells in jegs / summit seem to have Gm sender. I like the powder coat red aluminum jegs cell but it only comes with the Gm sender (0-90 ohm) and not the Mopar(70-10 ohm). Any recomendations? BTY I want to do something very similar to your car with mine, 69 Bee 440/ 4speed full car street driven on 93 Pump gas.
