tire size translation please!
#1290604
08/24/12 07:24 PM
08/24/12 07:24 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
please help an 'old skool' guy understand metric tire sizes. i thought i had it figured out then some recent post threw me. G70-15 = G78-15 = F70=15 = thanks ![](/ubbthreads/images/graemlins/bow.gif)
Re: tire size translation please!
[Re: mikemee1331]
#1290609
08/24/12 09:28 PM
08/24/12 09:28 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
thanks Dan! and yes Rod it's been a long nap and the trouble with looking online is 1 place says one thing and another will say something else. i went straight to Mickey Thompson and got 2 different answers from 2 different people. Trust me, ive tried to figure out what each number means. the last number is the only one that makes sense to me
That's because they aren't EXACT conversions. Think of a word in English and another language. Many are direct but some, especially slang, do not translate literally. The only reason you would need to convert the late 60s early 70s tire sizes is because you want an exact replacement for OE equipment. The metric radials are NOT exact replacements. Also, darn near every tire shop will offer a recommended tire size according to application. You want a Challenger R/T tire? They have that listed. So if one says 225/75R15 and another says a 215/70R15, they are both close but one is the same height and fatter, the other is the same width but shorter.
If you have looked at any of the explainations of tire sizes, you can see that a 215 tire is much more descriptive than a G tire.
A 215 tire bulges out to 215mm across the width of the tire when mounted on the proper width rim and inflated to the proper pressure. How wide is a G tire? ![](/ubbthreads/images/graemlins/shruggy.gif)
The second part is 70, 75, etc. This is the same on the older stuff and the new. A 100 tire would be as tall from the rim as it is wide. A 50 series tire will be half as tall as wide.
http://en.wikipedia.org/wiki/Tire_code
[Re: deansrr]
#1290612
08/25/12 02:47 AM
08/25/12 02:47 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
G70-15 = 215/70/15 G78-15 = 215/75/15 F70-15 = 205/70/15
quote was off a size, above is right!
I respectfully disagree the tires you are recommending are all too NARROW & too SHORT!
For years Corvettes put F70-15s on 8" wide wheels, put a 205/70/15 on an 8" wheel & you'll see how SMall they are.
[Re: 6bblgt]
#1290613
08/25/12 07:56 AM
08/25/12 07:56 AM
mikemee1331
bethlehem pa
that's exactly what size i have on the front of my RR and they are tiny. there's no height at all. 8" front rims. and i don't remember F70's being that way.
