PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY #1289864
08/22/12 11:59 PM
08/22/12 11:59 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Can someone please post a pic of the proper placement and mounting of a duel horn setup on a 69 B Body. Thanks
Re: PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY [Re: frank] #1289865
08/23/12 09:12 AM
08/23/12 09:12 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
1969 Charger
Re: PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY [Re: gtx6970] #1289866
08/23/12 11:49 AM
08/23/12 11:49 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Here is pic of horns on my 70 B Body, prior to removal . . . think it would be the same . . .
Re: PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY [Re: gtx6970] #1289867
08/23/12 11:55 AM
08/23/12 11:55 AM
It's a dry heat
It's a dry heat
On 1969 and earlier, the horn relay mounts right there with the horns. I don't think 1970's do ?
Re: PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY [Re: gtx6970] #1289868
08/23/12 03:05 PM
08/23/12 03:05 PM
a12rag Offline
a12rag  Offline
Correct, the horn relay is under the dash, with just the wires from the relay going out to the horns themselves . . . my car was original unmolested when I took it apart, so I am sure this is true for 70.
Mark
Re: PLEASE POST PIC OF DUEL HORN INSTALLED ON B BODY [Re: a12rag] #1289869
08/23/12 03:24 PM
08/23/12 03:24 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks all. The horns that I took out of this car are attached together with a bracket. They are not separate. I would assume the hornes I have are not correct?
