E Body Brake Cable/Brake Hose Retainer Clips #1289851
08/22/12 10:38 PM
08/22/12 10:38 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content OP
44D6PAKCUDA  Online Content OP
I know they are different being there are part numbers for both,but can someone post correct photos of the front(disc) and rear brake hose retainer horseshoe shaped clips and the emergency brake cable horseshoe shaped clips.The car in question is a '70 E Body.Have they change from assy line version to over the counter version over the years?Thanks for any info.
Re: E Body Brake Cable/Brake Hose Retainer Clips [Re: 44D6PAKCUDA] #1289852
08/23/12 08:12 AM
08/23/12 08:12 AM
MA
steve70 Offline
steve70  Offline
MA
Here's the front
1970 Challenger T/A 4 speed
Re: E Body Brake Cable/Brake Hose Retainer Clips [Re: steve70] #1289853
08/23/12 08:16 AM
08/23/12 08:16 AM
MA
steve70 Offline
steve70  Offline
MA
Here's the rear
Re: E Body Brake Cable/Brake Hose Retainer Clips [Re: 44D6PAKCUDA] #1289854
08/23/12 08:59 AM
08/23/12 08:59 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
brake hose clip is - 2208893
park brake cable clip is - 2201467
both still avail thru any mopar dealer
sae pice today as back then.
DO NOT use the yellow zinc plated repops, they break
Re: E Body Brake Cable/Brake Hose Retainer Clips [Re: steve70] #1289855
08/23/12 10:27 AM
08/23/12 10:27 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Here's the front
The clip is upside down
Re: E Body Brake Cable/Brake Hose Retainer Clips [Re: gtx6970] #1289856
08/23/12 01:08 PM
08/23/12 01:08 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Here's the front
But it probably ain't comming off!
