Re: Wipers won't park
[Re: wally426ci]
#1289488
08/22/12 11:01 AM
08/22/12 11:01 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
I have that problem too. 71 Challenger, variable switch, unknown if 3-spd motor or variable... if there is a difference.
Watching to see what other people say.
There isn't , it's the switch that makes it 3 speed or variable .
[Re: JohnRR]
#1289490
08/22/12 12:54 PM
08/22/12 12:54 PM
Posts: 2,554 Maryland
wally426ci
Maryland
Thanks!
Hijack over.
[Re: Challenger 1]
#1289494
08/22/12 09:43 PM
08/22/12 09:43 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
check the blue wire (single wire heading into different part of motor) to see if it has power when the switch is off. If it does than the problem is the wiper motor not the switch. Also if it wont park and there is power at the motor, try tapping the motor lightly with a hammer and see if it makes contact and parks. Usually sign that motor needs serviced.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: DGS]
#1289495
08/22/12 11:05 PM
08/22/12 11:05 PM
Posts: 18,157 Mass
DAYCLONA
Mass
how's the motor grounded? Through the 3 screws that hold it to the firewall?
1 bolt will ground it, it's the one that has the brass sheetmetal strap, grounds from the firewall bolt/stud to the motor case screw.... also check the sheetmetal frame that mounts the switches, behind the plastic dash panel, a poor ground there can also prevent the motor from fully parking sometimes
[Re: DGS]
#1289497
08/23/12 10:18 AM
08/23/12 10:18 AM
Posts: 2,984 Montreal,Quebec,Canada
JulesdaWiperman
super gas
super gas
3 speed motors ( or variable in 70-71 E bodies) work like this. When you turn your dash switch to the OFF position you are actually not doing that. The switch is reversing the rotation of the motor so that it can actuate an internal cam that will open a contact within the motor and therefore cut power. That is why you may notice sometimes that the motor hesitates during its sweep motion when you click your dash switch to off. Now that does not narrow down your problem to the switch or to the motor. Your car may just have a bad ground. IF your dash switch is not grounded or your motor is not grounded properly, then this may be your problem. Check that all your wires are making good contacts on the bulkhead connector. If all this checks out, try another switch before you go through all the hassle of taking out the one in the dash right now.Just make sure you ground the casing of the switch before you do your test. If the switch tests okay, then the park mechanism within the motor may be faulty. The motor can be tested without taking it out of the car. Contact me if you need further help. Jules 450-656-5438 Check out my Youtube video about ground problems on E bodies. http://www.youtube.com/watch?v=UmP3SYjdQSQPlease ignore the song in the background. Nice motors there Mike.
[Re: DGS]
#1289500
08/23/12 10:17 PM
08/23/12 10:17 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I dont remember without looking at the wireing pic but alot of wiper systems when turned to park reverse like Doc said and many go back and ground thru the switch in the park mode. Ron
[Re: JulesdaWiperman]
#1289502
08/24/12 01:26 AM
08/24/12 01:26 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Low Speed.
Green to ground. Brown and Red together with power. Nothing on Blue
Top Speed.
Green to ground. Brown with power. Nothing to REd Nothing to BLue
Park.
Red to ground Green and Brown together. Blue with power.
Jules
I vote for archive. Good stuff. Not in the FSM, AFAIK.
