Re: Delay Box Help
[Re: BlueDart]
#1289207
08/21/12 06:09 PM
08/21/12 06:09 PM
When you leave with no delay are you on a two step or on the mat?
Maybe with the little extra time with the delay, the motor has a little more time to RPM and it can get you into the sweetspot of the converter so it leaves harder.
Do you have any kind of recording device on the car?
Re: Delay Box Help
[Re: superstreet1896]
#1289209
08/21/12 06:31 PM
08/21/12 06:31 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
I'm thinking it likely has something to do with when you are getting on the chip. In my car we just ad the time between whatever pro tree and full tree and are fine. I know a lot of guys get to pedal matted as soon as the first amber comes down. My guess is you are seeing a tad more temp which may be causing the converter to flash a bit higher once the button releases. If you are not leaving on a chip you are likely seeing more stall speed off the converter due to more heat being in it.
Re: Delay Box Help
[Re: Kenny705K]
#1289212
08/21/12 10:52 PM
08/21/12 10:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Most likely its like Al said... conv... but I dont know why you care.. so what if its not linear just put more time in the box.... are you using a data system if so that should tell you why... if you measure the trans temp EDIT also what box are you using
Re: Delay Box Help
[Re: poisondart2]
#1289216
08/22/12 01:00 PM
08/22/12 01:00 PM
Al_Alguire
Las Vegas
The ".370-.385" light is for NHRA NATIONAL events only. It does not pertain to divisional or local bracket programs. So it is a moot point. It was done for Pro Stock and Pro Stock bike mainly to help cut down on red lights.
Re: Delay Box Help
[Re: MR_P_BODY]
#1289217
08/22/12 01:16 PM
08/22/12 01:16 PM
Posts: 51 Vacaville, Ca
Kenny705K
Vacaville, Ca
I don't care, and have no problem adding the time to the box but I was wondering if anyone could explain why, because it doesn't make sense to me. I guess I cared on Sunday when it cost me on raceday but now I am just curious. I'm using a Biondo Little Wizard. I don't see how converter could be the issue. I doubt I'm on the converter any longer/shorter than when I run the pro tree
Re: Delay Box Help
[Re: Kenny705K]
#1289218
08/22/12 01:22 PM
08/22/12 01:22 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
kenny
what timing system are they using? it should be printed on the ticket.
Joe
Without Data, you’re just another guy with an opinion.
Re: Delay Box Help
[Re: Kenny705K]
#1289220
08/22/12 01:40 PM
08/22/12 01:40 PM
Al_Alguire
Las Vegas
Kenny you guys usually video the races right? Check the tape and see if you may on the converter varying amounts? Either way could be the issue, just curious. As I say we just simply ad the amount for the tree, nothing else. Staging a tad shallower when on a full tree could account for a little as well. I try to be in first most times just so I can stage exactly how I want to. But you are a great racer and do you share of winning so you dont need my advice.
Did you guys open a shop in Fairfield on Texas? I was just there and saw a Moorhead Auto on the curve there.
Re: Delay Box Help
[Re: Al_Alguire]
#1289221
08/22/12 06:55 PM
08/22/12 06:55 PM
Kenny705K
Vacaville, Ca
That is not our shop, but it's my Dad's 2nd cousin I think. I only met them once years ago. Thanks for the input. I will just have to add it and not worry about why it happens lol
Re: Delay Box Help
[Re: Kenny705K]
#1289222
12/14/12 03:25 PM
12/14/12 03:25 PM
sr4440
Central TEXAS!!!!
I bringing this back from the dead because I finally got a answer back from Jeff foster. Quote:
Jeff
Sorry to bother you but there is a discussion on another board about the Christmas tree lights. I was under the impression that all “pro tree” lights are now .370 but some insist that this is “only” for select classes IE pro stock, pro stock bike. Can you shed some light on the subject (no pun intended)
Thanks for your time Joe
his response
Sorry for the delay in response, I don't check the PMs often. as for the questions, all pro light classes in NHRA IHRA and most pro mod/ Pro street groups run it as a .370 tree
Jeff Foster Compulink
Joe
