Page 4 of 4 1 2 3 4
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288982
08/22/12 08:37 PM
08/22/12 08:37 PM
Smyrna, South Carolina
STEFF Online content
STEFF  Online Content
Hi,Gary! Yes!..Steff replaced the section under the steering box...and reinforced it. Gary..would dropping the pinion angle from 5* to 7* help anything? Thanks! I think down the road,I'm going to have you check EVERYTHING out and advise me on what can be done to optomize my set-up!
I only did the front. The back still needs alot of attention.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Sport440] #1288983
08/22/12 08:37 PM
08/22/12 08:37 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
I'm sure it will dip into the 10's with the increased power. I bet the 60 ft times improve as well with the added compression and head flow.
Ron
No problem!
x2. And with a bit of sensible tuning also!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: HYPER8oSoNic] #1288984
08/22/12 09:28 PM
08/22/12 09:28 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Randy, I agree with Gary. Work on optimizing what you have and you will be very happy. Some good chassis tuning and track tuning on the motor and you will have a sweet ride, especially with the new paint. But if you change your mind.....
Randy
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? *DELETED* [Re: Labratt] #1288985
08/22/12 11:09 PM
08/22/12 11:09 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Post deleted by mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: mopar65] #1288986
08/23/12 12:39 AM
08/23/12 12:39 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks everyone! Like Steff stated..."the back frame needs some attention" He's referring to the rear of the car being weak...due to some frame-rail rot. Unfortunately,I was on a tight deadline to get the car to the painter...or I would have had him repair it then. It definately has to be addressed in the near-future! Again...thanks for all your opinions,and information! Randy B.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288987
08/23/12 01:03 AM
08/23/12 01:03 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If the rear rails are not in the best shape and allowing flex, that will definitely eat up power that could be used for going forward. Get that thing gusseted up!
Clamp the front segments and loosen up the rears. May not help with the rails in rough shape...
Keep chipping away at it and set a goal in the low 1.40's.
Good luck with it.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: RobX4406] #1288988
08/23/12 01:33 AM
08/23/12 01:33 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Rob! I plan on having Steff gusset the frame rails over the winter...or next Spring.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288989
08/23/12 02:07 AM
08/23/12 02:07 AM
RobX4406 Offline
RobX4406  Offline
Love the car, wish my GTX looked anywhere close to yours!
I'd also probably put more converter in it. That's just me!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288990
08/25/12 12:05 AM
08/25/12 12:05 AM
Desert Tracker
Desert Tracker
Gusset it or use "box type" steel to replace the rear frame. Your traction woes will be drastically
reduced and the 60 ft times will go down. Once your car is "hooking" off the line well (and consistent) THEN start tuning for speed.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: HYPER8oSoNic] #1288991
08/25/12 10:48 AM
08/25/12 10:48 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Rob..Ron! Steff's a real sharp guy!..he'll know exactly what should be done to fix my problem! As far as converters go...more than a few people suggested I go to a looser 8" unit,but I don't know....I've had GREAT luck with my 9.5" Dynamic! But...I'm thinking,since everything's still apart,and not installed in the car yet..could be a possibility!..but only if I were to sell my Dynamic first!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288992
08/25/12 11:57 AM
08/25/12 11:57 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
All I can say is you got a better motor than us. and weight close to the same and we run 11.00s alot ?
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: VernMotor] #1288993
08/25/12 12:02 PM
08/25/12 12:02 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Vern!...that's because you're a darn mechanic..and do a GREAT job with tuning that Coronet! And...you have Jenny as a driver!...nuff' said!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288994
08/25/12 12:50 PM
08/25/12 12:50 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Converter def. is a big part of your 60' I run a coan 8" with around 5000 flash speed. Suprisingly it drives on the street better then my last 9.5" 4000 converter I had in it. I love my coan .
67' charger 499 RB 10.57 at 127
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: dragram440] #1288995
08/25/12 12:59 PM
08/25/12 12:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have a 8" Coan in mine also. Really surprised with it's street manners.
Drives like there's a 10" street vert in there but will flash to 5K on command
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: roadhazard] #1288996
08/25/12 02:44 PM
08/25/12 02:44 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,fellers! I just might be re-thinking my converter choices! ANYBODY need a perfectly good 9.5" Dynamic???
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288997
08/25/12 02:53 PM
08/25/12 02:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, I run a 9.5" Dynamic...
My $.02: stop swapping out more parts before you've even had a chance to see what the new combination does.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1288998
08/25/12 03:42 PM
08/25/12 03:42 PM
Desert Tracker
Desert Tracker
As BradH stated, work with what you presently have. Perfect the combo you have by tuning (both chassis and engine)and sound driving techniques meaning "knowing" what the car "likes" and "dislikes". Worry about the parts combo AFTER
you find out from tuning! Money can be "saved" through this approach for the ESSENSIAL parts UPGRADES! Don't FALL into the "Keeping up with the Joneses" approach. Hardly any good results through this method.
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: HYPER8oSoNic] #1288999
08/25/12 04:04 PM
08/25/12 04:04 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Brad..Ron,points well taken! I'm sure with the improved heads..and Steff re-doing the frame rails,I SHOULD be seeing some 10 second time slips! Now..just gotta put the X back together again!
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: Labratt] #1289000
08/27/12 01:32 AM
08/27/12 01:32 AM
Desert Tracker
Desert Tracker
FWIW (Steff may have this in mind already), outside of the frame rail repairs, reinforce the upper rear shock mounts and the area above the nose of the pinion housing, IF you are going to use a pinion snubber. It's to provide a solid contact surface for the snubber (distributes the weight transfer/engine torque shock to the chassis).
Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ??? [Re: HYPER8oSoNic] #1289001
08/27/12 11:42 PM
08/27/12 11:42 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Ron..good ideas! I will definately mention doing BOTH to Steff..when the time comes to fix the rear rails! Thanks!
Page 4 of 4 1 2 3 4
