Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ???
[Re: Labratt]
#1288982
08/22/12 08:37 PM
08/22/12 08:37 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
Hi,Gary! Yes!..Steff replaced the section under the steering box...and reinforced it. Gary..would dropping the pinion angle from 5* to 7* help anything? Thanks! I think down the road,I'm going to have you check EVERYTHING out and advise me on what can be done to optomize my set-up!
I only did the front. The back still needs alot of attention.
[Re: dragram440]
#1288995
08/25/12 12:59 PM
08/25/12 12:59 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Thanks Rob..Ron! Steff's a real sharp guy!..he'll know exactly what should be done to fix my problem! As far as converters go...more than a few people suggested I go to a looser 8" unit,but I don't know....I've had GREAT luck with my 9.5" Dynamic! But...I'm thinking,since everything's still apart,and not installed in the car yet..could be a possibility!..but only if I were to sell my Dynamic first!
Converter def. is a big part of your 60' I run a coan 8" with around 5000 flash speed. Suprisingly it drives on the street better then my last 9.5" 4000 converter I had in it. I love my coan .
I have a 8" Coan in mine also. Really surprised with it's street manners. Drives like there's a 10" street vert in there but will flash to 5K on command
[Re: Labratt]
#1288997
08/25/12 02:53 PM
08/25/12 02:53 PM
BradH
FWIW, I run a 9.5" Dynamic... My $.02: stop swapping out more parts before you've even had a chance to see what the new combination does.
[Re: HYPER8oSoNic]
#1288999
08/25/12 04:04 PM
08/25/12 04:04 PM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
As BradH stated, work with what you presently have. Perfect the combo you have by tuning (both chassis and engine)and sound driving techniques meaning "knowing" what the car "likes" and "dislikes". Worry about the parts combo AFTER you find out from tuning! Money can be "saved" through this approach for the ESSENSIAL parts UPGRADES! Don't FALL into the "Keeping up with the Joneses" approach. Hardly any good results through this method.
Brad..Ron,points well taken! I'm sure with the improved heads..and Steff re-doing the frame rails,I SHOULD be seeing some 10 second time slips! Now..just gotta put the X back together again!
[Re: Labratt]
#1289000
08/27/12 01:32 AM
08/27/12 01:32 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
FWIW (Steff may have this in mind already), outside of the frame rail repairs, reinforce the upper rear shock mounts and the area above the nose of the pinion housing, IF you are going to use a pinion snubber. It's to provide a solid contact surface for the snubber (distributes the weight transfer/engine torque shock to the chassis).
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
