`70 Road Runner 440-6bbl keeps konking out!
#1286610
08/16/12 09:48 PM
08/16/12 09:48 PM
Posts: 9,838 Detroit, Michigan, USA!
peelerboy
Okay, guys... here's the deal: My buddy has a very nicely restored 1970 Road Runner, 440-6bbl, 4spd, all done to stock trim and specifications. (original dual point distributor and everything) It just recently starting "acting up" whereas the car suddenly dies. It could be idling at a stoplight, driving down the road at 40mph, doesn't matter. The car will suddenly and inexplicably konk out and cease to run. When this occurs, the car still has electrical power. Such that, the starter will crank, the lights continue to be lit, horn works, etc. When you try to restart it, it will catch and sometimes it'll run for 5 minutes...maybe 5 hours...maybe only 5 seconds before it quits again. It's as though someone has turned off a lightswitch on the ignition and it's done. We've checked the spark, and it has it. We double checked the fuel (even thought it isn't puttering out like it's running out of gas), and gas is flowing freely in the center carb when you pump it. It's just totally random and intermittent. We've replaced the ballast resistor a few times (with both new and used pieces), checked all the wiring (brand new harnesses everywhere), checked all the connections on the wires including at the bulkhead connector, even swapped out the condensor on the distrib with a new piece. Nothing is affecting the random shut downs. We're at a loss. I'm sure we're looking right past whatever the problem is... hiding in plain sight right in front of us, but we don't know what it could be. Suggestions?... please? Thanks in advance!
Re: `70 Road Runner 440-6bbl keeps konking out!
[Re: peelerboy]
#1286612
08/16/12 10:05 PM
08/16/12 10:05 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Check/kleen the bulkhead connections.. Unplug each, wire brush any oxidation, titen the female crimp connector and coat with dialectric grease and reinstall... Just my $0.02...
[Re: mikemee1331]
#1286613
08/16/12 10:06 PM
08/16/12 10:06 PM
peelerboy
when it won't run do you have spark out of the coil? i'm guessing you don't. what condition are the points in?
The points are nice and meaty and gapped correctly. I only checked for spark (at the coil) one of the times it did this and yes... it had spark. But like I said, the condition is intermittent. So, couldn't the spark return just long enough for me to check it, then fail shortly thereafter? It totally acts like ignition, though. It's just a clean cut-off to power.
[Re: Sinitro]
#1286615
08/16/12 11:18 PM
08/16/12 11:18 PM
peelerboy
Go to the post above your last post and do what he said!
That's too weird! After my second post, I refreshed the page and did NOT see it! When I refreshed it just a moment ago, I saw your post and thought, "What's he talking about?!" Low & behold...there WAS another post! Ha! Thanks for the heads up!!
Check/kleen the bulkhead connections.. Unplug each, wire brush any oxidation, titen the crimp conector and coat with dialectric grease and reinstall...
Juts my $0.02...
Good suggestion. Gonna' do it tomorrow for sure. Thanks!
And I'm going to try and catch the coil red-handed with no spark a couple more times, too.
[Re: peelerboy]
#1286616
08/16/12 11:24 PM
08/16/12 11:24 PM
RapidRobert
This is a tough one . I'd jumper from the batt positive post to the ballast & from the ballast to the coil positive primary terminal & see if it'll act up. This'll take all of the ign1 (run) circuit out of the picture
[Re: Rick_Ehrenberg]
#1286619
08/17/12 09:12 AM
08/17/12 09:12 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I had the same thing happen on my red 70' Sixpack Charger. It would just die whenever it wanted to. Most of the time when it was hot (at running temp). It turned out to be the parts store coil over heating. I bought a MSD blaster 2 coil & painted it black. That lasted several years but eventally started doing it again. I am back to another parts store coil & all has been fine for several more years. I think it has something to do with the location of the coil in the factory bracket that causes it to over heat over time????? My 440 4 BBL cars never do this with the coil mounted further up front hanging off of the front of the intake manifold.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Mr.Yuck]
#1286621
08/17/12 09:50 AM
08/17/12 09:50 AM
Posts: 3,000 Long Island, NY
shakerjoe
Long Island, NY
my friend had the exact same thing happening, couldn't figure it out - this was on a freshly restored "everything" 440-6 70 Challenger R/T, and I mean everthing...so it stalls one day while we're out, I'm looking it over, and I notice the coil is kind of "wet" looking - oily residue around the top - it was leaking and heating up and brreaking down I figured, swapped for a new coil and hasn't happened since - not leaking either. I also had the same problem, like someone just reached in my window and shut the ignition off while doing 60 or idling, spoke to a friend at the dealer where I picked up my MP electronic ignition kit and he told me the orange boxes were possible subject to heat soak - to try a chrome box - that was about 8 years ago - never happened again after I swapped to the chrome from orange...my
[Re: Tony440]
#1286623
08/17/12 10:13 AM
08/17/12 10:13 AM
peelerboy
Great, great info you guys! I still have yet to check out the connections at the bulkhead to rule that out... but it sure sounds like a lot of you have experienced difficulties with the coil. That's such an easy check/swap that I might try that first. Oh, and yes I'm aware of some of the Mopar ignition boxes failing (good suggestion as well!), but this car is equipped with a totally factory correct ignition. (points) Thanks again guys, and I'll keep you posted! Dale
[Re: crazyjjk]
#1286625
08/17/12 11:51 AM
08/17/12 11:51 AM
peelerboy
still dont forget the points condenser. They have a tendency of get hot and shorting also.
Thanks!...but we replaced that with a brand new one and didn't make a difference. Worth mentioning, though!
[Re: peelerboy]
#1286626
08/17/12 01:48 PM
08/17/12 01:48 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Check ballast resitor and connection and amp meter connection.Steering column to wiring harness connection prone trouble area
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: shakerjoe]
#1286627
08/17/12 02:51 PM
08/17/12 02:51 PM
Posts: 1,152 Colorado
CuriousYella70
Colorado
my friend had the exact same thing happening, couldn't figure it out - this was on a freshly restored "everything" 440-6 70 Challenger R/T, and I mean everthing...so it stalls one day while we're out, I'm looking it over, and I notice the coil is kind of "wet" looking - oily residue around the top - it was leaking and heating up and brreaking down I figured, swapped for a new coil and hasn't happened since - not leaking either. I also had the same problem, like someone just reached in my window and shut the ignition off while doing 60 or idling, spoke to a friend at the dealer where I picked up my MP electronic ignition kit and he told me the orange boxes were possible subject to heat soak - to try a chrome box - that was about 8 years ago - never happened again after I swapped chrome for orange...my
I think shakerjoe hit the nail on the head with the coil solution. I know it's not the same as the RoadRunner but my old Dakota did the same exact thing your RoadRunner is doing. It would cut off and then sometimes you couldn't get it to start or sometimes it would start right back up, would always cut all power immediately. Turns out, the oil inside the coil had slowly leaked out to where it would cut all power whenever i turned, was sitting at a light, etc. - it would always lose connection. I say try a new coil and see if that doesn't solve your problem right away!
