Re: Another Question On A-Body 440 Headers
[Re: Dustin71]
#1286312
08/16/12 04:29 PM
08/16/12 04:29 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Look at the Pro Parts headers that Bob Mazzolini sells.
[Re: Cab_Burge]
#1286315
08/16/12 10:15 PM
08/16/12 10:15 PM
Posts: 197 New York
Dustin71
New York
With you on that Cab ... I'm on my 5th Duster since 1989 and 4 of them got the Fenderwells Cut out for the F/well headers ...This one i got now i bought from one owner and is in great shape so i would like to go with out cutting this one up ...the thing is that !!!DAM!!! those TTi's ar pricey !!! So i was looking around and did some re-search and it all points to TTi's .... The Part number i posted on top are For HOOKER headers Fenderwells i just found out ...(Year one part number)So they won't Do!!!! I will be Placing an Order Tomarrow For the TTi's .... Thank's again Guy's for ur On this ... Thank you also Chris ...
[Re: Dustin71]
#1286317
08/17/12 12:18 AM
08/17/12 12:18 AM
Chris2581
Jacksonville, FL
You can run tall tires with the Pro Parts style and they are a semi fenderwell header.
[Re: Cab_Burge]
#1286319
08/17/12 02:34 PM
08/17/12 02:34 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Those won't work on a low deck in a stock A body 383 car Ask me how I know
Would they work with a low deck and raised port heads, such as 440-1s?
[Re: dennismopar73]
#1286324
08/17/12 05:58 PM
08/17/12 05:58 PM
Posts: 197 New York
Dustin71
New York
I'll throw my 2 cents in , we have had 2 sets of TTIs neither set fit a body big block, 400 or 440 without work!!
Really ? i guess i will have to Pray that they will work on my A-body Duster ...I own them now so as soon as they arive , i will post Comments with picture and share weather good or Bad...Wish me Good luck...
[Re: Chris2581]
#1286326
08/17/12 11:05 PM
08/17/12 11:05 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I have used the same set of PP headers with my 383 and 440 using 452 and 906 heads,so I will disagree on that Cab.
Did you get the early, original PP with the two inch primarys or the later ones that Bob Mazzolini had TTI make with the Pro Parts jigs? Mine are the 2 inch originals, not the CPPA that Hedman made or the later ones They hit the standard starter and the mini starter, the oil pan, even after flattening the one pipe some This is a stock 383 with 906 heads on the stock 1969 OEM mounts in a 1969 GTS No sense in lying or misleading on these headers, there not made anymore I'm going to put EGT bungs in them and use them for dyno testing from now on
[Re: Cab_Burge]
#1286327
08/17/12 11:29 PM
08/17/12 11:29 PM
Chris2581
Jacksonville, FL
They are the early headers.In fact this set I know is going on 25 years.Bought them from Herb McCandless.No doubt they fit a lot better when I run a 440,but they do fit the 383 too.
