PROJECT GAS SIPPER 67 Plymouth Valiant #1286185
08/16/12 02:50 AM
08/16/12 02:50 AM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
I'm on a mission to find a gas sipper. I know a 67 plymouth isnt what firat comes to mind when the phrase "gas sipper" is said...THAT being said, here is my next project
How she has been sitting for the last few years. She had been covered for MOST of those years, but stuff happens
What a beautiful rear end..MUCH more appealing than Kim Khardashian
Aired up the tires
Hooked the chain to it and the truck. I'm not straight because of how the rest of the yard is, and where its going
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286186
08/16/12 03:11 AM
08/16/12 03:11 AM
woodcrest, CA
woodcrest, CA
Got it drug out, and gave her a bath
After a bath:
Lights still work
The "Leaning tower of power" ....LITERALLY. 2 broken motor mounts
Only surface rust in the trunk
Interior is WAY worse than I remember it...Then again, the last time I looked at this car was maybe 2 years ago
Someone replaced the seats with blue seats at one point in her life. Here is the back seat
Thats it for now. I ran out of time to do anything else with her tonight. She is going to have to wait..
I accidentially broke the ignition back, and while trying to fiddle with her, to see if other things worked (blinkers, yes, heater fan, yes) I accidentially cranked her
I wanted to oil the cylinders first. MAYBE if I can tomorrow, I will head over there to oil the cylinders. We tilted the motor enough to access the distributor, so with a battery, and gas, she might run
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286187
08/16/12 04:57 AM
08/16/12 04:57 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
So what are the plans?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: OhioMopar] #1286188
08/16/12 10:08 PM
08/16/12 10:08 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Yeah...sounds like a fun project. Turbo efi 2.2L through a Dakota 5 spd?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286189
08/16/12 10:32 PM
08/16/12 10:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What's the scoop on the 67 Belvedere sitting in the background?
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: OhioMopar] #1286190
08/17/12 01:35 AM
08/17/12 01:35 AM
woodcrest, CA
woodcrest, CA
plans are to get her running, to see where I'm at in the first place. THEN depending on whether it smokes, knocks, whatever, that's when I'll decide. I actually picked this car because its auto. I'm tired of shifting a truck. Maybe a car will be different but the auto is staying. UNLESS it's toast
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: ScottSmith_Harms] #1286191
08/17/12 01:37 AM
08/17/12 01:37 AM
woodcrest, CA
woodcrest, CA
Thats a 67 GTX.
It belongs to a friend of the shop
BELIEVE ME, I asked about it when it first showed up, and again tonight
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286192
08/17/12 02:22 AM
08/17/12 02:22 AM
woodcrest, CA
woodcrest, CA
Made some progress tonight. I was given an ignition switch to replace the one that fell apart in my hand yesterday. We pulled the plugs, oiled the cylinders, then cranked the motor until the oil light went out.
Tried to start her, but after a few fails, we discovered the timing chain is WAY stretched. I ordered a new one, it will be here tomorrow, then I get to spend tomorrow night putting it in
On a brighter note. Here is what I pulled out of the engine when I pulled the thermostat housing
Definately is a 170...but what does the DW stand for?
All tucked in for the night
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286193
08/18/12 02:18 AM
08/18/12 02:18 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Drag Week.
CrAzYMoPaRGuY
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: CrAzYMoPaRGuY] #1286194
08/18/12 10:47 AM
08/18/12 10:47 AM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Drag Week.
Doesn't Work
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: TX9H6E4CUDA] #1286195
08/18/12 07:59 PM
08/18/12 07:59 PM
woodcrest, CA
woodcrest, CA
Drag Week.
Doesn't Work
Doesn't work is correct for right now
The timing chain was really stretched, an so I replaced it.
Still doesn't work
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286196
08/30/12 12:38 AM
08/30/12 12:38 AM
woodcrest, CA
woodcrest, CA
made some progress on the valiant. I got the nasty smelling interior stripped out to see the damage on the floor boards
Here is the passenger side. someone already did the cheap redneck fix on the passenger side already
A decent day. I scored the 68 taillights to put in there temporarily until I find a good set of 67 lights. I got the horrible horrible interior out, and best of ALL, I SCORED a A833 out of an 83 truck NOW the hunt is on for a 4 speed pedal set, and a slant six car bellhousing
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286197
09/01/12 05:11 AM
09/01/12 05:11 AM
woodcrest, CA
woodcrest, CA
nothing MAJOR done. I got the sun visors I bought off the forum, and they look AWESOME, minus 2 dents from a mirror. no worries, as its getting installed dent up haha
In my quest to learn auto upholstery, I attempted to restore the passenger visor that came with the car...
It didn't come out too bad. I am going to do the tan drivers side next. I want to do my own upholstery, and every bit of practice I can get in, will make a HUGE difference
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286198
09/02/12 09:58 PM
09/02/12 09:58 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I think dw stands for dead weight.
Neat project.
Upholstery you better get a sewing machine. I like my old singer
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: snuggles] #1286199
09/02/12 10:00 PM
09/02/12 10:00 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
Dustergirl has a good writeup about seat covers if its still on her website
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: snuggles] #1286200
09/05/12 07:23 AM
09/05/12 07:23 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
She has a website?
1969 Dart GTS 340
2015 Dodge Dart GT
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: OhioMopar] #1286201
09/05/12 09:23 PM
09/05/12 09:23 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
She has a website?
http://www.breakstuffracing.com/index2.html
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: snuggles] #1286202
11/08/12 04:54 AM
11/08/12 04:54 AM
woodcrest, CA
woodcrest, CA
no REAL progress... I havent even brought her home yet. No room in the driveway, because of other peoples crap...thats slowly getting taken care of Had time only for 1 bulky item drop off day last month...next one is on the 17th
Had to get newish tires for her to roll on..OLD:
Can't tell that the new ones are on her..well...USED, but new to her. Had to drive to every shop in town to find a shop that had 13's:
Had to get tires on her that hold air for longer than an hour. Not only because I had to move the car so they could get herc out of his spot, but because of code enforcement HERE, I have to make it look ok for when its over here...
No updates besides tires, and moving her lol
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286203
11/24/12 01:07 AM
11/24/12 01:07 AM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
Reminds e of the Valiant I got rid of
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: mopar383] #1286204
06/23/13 01:20 AM
06/23/13 01:20 AM
woodcrest, CA
woodcrest, CA
Update long time coming. Finally got back to the Plymouth. Changed motor mounts. Old passenger side:
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286205
06/23/13 01:26 AM
06/23/13 01:26 AM
woodcrest, CA
woodcrest, CA
Another of the old passenger side, next to the new one. I am holding the old one together for picture purposes
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286206
06/23/13 01:38 AM
06/23/13 01:38 AM
woodcrest, CA
woodcrest, CA
New one installed. No more distributor resting on fender
We think when the motor mount went, it caused the distributor to get knocked out of time. I ran out of time (no pun intended) to try and start her tonight.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286207
06/23/13 01:41 AM
06/23/13 01:41 AM
woodcrest, CA
woodcrest, CA
Drivers side. No pics of it installed. Got too late
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286208
06/23/13 02:33 AM
06/23/13 02:33 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
....and your MPG goal is going to be ?......
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: dOrk !] #1286209
06/23/13 02:35 AM
06/23/13 02:35 AM
woodcrest, CA
woodcrest, CA
Hoping to get close to 30 MPG's. My buddy tim is trying to talk me into fuel injection. We shall see haha
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286210
06/23/13 02:38 AM
06/23/13 02:38 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
YOU will need one of my ONE HALF a THERMOquad conversions !
.....and take a guess at what the BEST MPG I have ever heard of on a /6 A-body stick shift car ....
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: dOrk !] #1286211
06/24/13 12:30 AM
06/24/13 12:30 AM
woodcrest, CA
woodcrest, CA
She runs
So after fiddling around a bit, turns out I was a tooth off on the timing set. Pulled the cover off, re did the timing, put new points and a newer coil on, and she fired
Of course we had previously pulled the plugs, oiled the cylinders, and hand cranked her over a few times.
She fired up, and was firing on all 6 cylinders. There was a light thump/tap that my buddy says could be a main.
NO smoke though
So now I am going to buy stuff to finish the front of the motor (water pump, thermostat and housing, belts/hoses) reason being, is now it'll be able to be moved around the shop under its own power assuming the trans is any good.
But I have a lead on a 225 that supposedly runs great and come with a working 904 that's going to get gone through and dropped in. But for now, it runs for the first time in 10+ years
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286212
06/24/13 01:22 AM
06/24/13 01:22 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
D - Series (model year) 1968
W - Windsor engine assembly plant
170 - 170 CU displacement
2239 - Engine final assembly date from the 10,000 day calendar - Sept 14, 1967 (1968 model year)
0332 - 332nd engine assembled at the plant above on the date above.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: Alaskan_TA] #1286213
06/24/13 01:26 AM
06/24/13 01:26 AM
woodcrest, CA
woodcrest, CA
Cool. Thanks
Now, would this motor be original to the car? Hood, fender, and some interior were from a 68 or 69. Could they have put the motor in there too?
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286214
06/24/13 01:33 AM
06/24/13 01:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Since the car is a 1967 model then yes, someone swapped the engine.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286215
06/24/13 01:14 PM
06/24/13 01:14 PM
woodcrest, CA
woodcrest, CA
Time to post some pics of getting her running.
Here is a comparison of the old points and the newer (new never installed) blue streak points. Not sure if the old points should look like that where the lobe rides haha
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286216
06/24/13 01:17 PM
06/24/13 01:17 PM
woodcrest, CA
woodcrest, CA
So not only were the points not opening enough, and not adjustable enough to get proper gap, they looked like they had been there since 67.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: magnum440d100] #1286217
06/24/13 01:23 PM
06/24/13 01:23 PM
woodcrest, CA
woodcrest, CA
As compared to the new one. Supposedly, this lady drove this car into the junkyard where my friend Dennis bought it from. She supposedly drove it every day with the broken motor mounts, spark plug wires rubbed through onto the shock tower, and who knows what else. The points tell a different story though. No way this car ran with those old points.
Re: PROJECT GAS SIPPER 67 Plymouth Valiant [Re: Alaskan_TA] #1286218
06/24/13 01:29 PM
06/24/13 01:29 PM
woodcrest, CA
woodcrest, CA
I figured as much. Well, since its not original, might as well get that 225 and drop her in. Just gotta get this car going good enough to move around the shop, and if code enforcement comes along, at least it starts.
I still hear a 440 calling my name for this car, but not the intentions I have for this car haha
