Page 12 of 25 1 2 10 11 12 13 14 24 25
Re: new Moparts fastest car list, post yours! [Re: MegaDart] #12854
05/08/05 09:30 PM
05/08/05 09:30 PM
Where am I?
Re: new Moparts fastest car list, post yours! [Re: 68DART360] #12855
05/09/05 12:05 AM
05/09/05 12:05 AM
Kentucky
Greencospeedshop Offline
Kentucky
--6 second Zone --
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
--7 second zone ---
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
8.02 @ 174+, The Haze, twin turbo 452", Leon Hudson, 65 Barracuda
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.17 @ 163, 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone ---
9.063 @ 146.23, Beeracuda, 74 Barracuda, 2800#, 499/PG
9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540
9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy,
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR
9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.91 and 142 mph,440 906 heads, Mrsixpak
9.972 @ 131.56, 1.350 60', Sleepyhead416
9.98 @ 131 040 over 440,727 Brake,stock eddie heads ,stock block/crank,solid tappet cam, 1970 Challenger 31.5 4:56s
---10 second zone---
10.03 @ 135 through exhaust
on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A.
10:14@129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035#
10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380#
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 @ 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 127.38, eeka440 73 Swinger 446 906's auto
10.70 @ 125 60' 1.50 3700 race weight 10secGTX
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---11 second zone ---
11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855#
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675#
11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned
11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.50 @ 115 1.55 60' 68DART360 ,904, 3200 lbs,eheads, pump gas,full exhaust, 10" tire SS springs
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.877 @ 112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91
11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone ---
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8
12.85 @ 105.43, 1.82 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
12:91@102, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 100 Top Gun shot, 3250#.
Officer to me...
"I had my pedal to the floor and you were still pulling away like a rocket!"
Re: new Moparts fastest car list, post yours! [Re: Greencospeedshop] #12856
05/09/05 12:52 AM
05/09/05 12:52 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
PLEASE use the most current list!!!
This is the third time I've had my time deleted/reverted to an older one because someone didn't quote the most recent post. It makes it really hard to keep everything up to date if we use the older lists. I know no one does it on purpose, but it is a little frustrating to have to keep revising it due to simple and avoidable errors. I don't mean to sound like a jerk, I just want to give a friendly reminder to help maintain the up-to-the-minute nature of this list. It wasn't until 2 pages ago that finally was no longer the slowest car on here.
-6 second Zone --
--7 second zone ---
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
10.98 @ 122.29, 1.55 60' Bubba, '80 Mirada, 440, 3855#
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
12:91 @ 102, 1.72 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 100 Top Gun shot, 3250#.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: new Moparts fastest car list, post yours! [Re: wyoming] #12857
05/09/05 06:36 PM
05/09/05 06:36 PM
i am amazed at the times some of you are getting out of your cars ! what are you doing to get into the 6's/7's & low 8's to these cars !? are they tube chassis with four link etc !? glass or steel bodies or a combo of both ? ..... very interested ........... steve
Re: new Moparts fastest car list, post yours! #12858
05/09/05 09:11 PM
05/09/05 09:11 PM
USA
dodge_nut Offline
dodge_nut  Offline
USA
12.17 @ 108 1.77 60', dodge_nut, 71 Charger, 440/727
Re: new Moparts fastest car list, post yours! [Re: dodge_nut] #12859
05/10/05 10:11 AM
05/10/05 10:11 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Here ya' go, dodgenut!
-6 second Zone --
--7 second zone ---
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
Re: new Moparts fastest car list, post yours! [Re: 67Charger] #12860
05/10/05 08:12 PM
05/10/05 08:12 PM
-6 second Zone --
--7 second zone ---
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
Re: new Moparts fastest car list, post yours! #12861
05/14/05 10:51 AM
05/14/05 10:51 AM
Pa.
BENCHRACER Offline
"Little Stroker"
BENCHRACER  Offline
"Little Stroker"
Pa.
I don't understand guys.
I'm on the list in the last posting of it on the 10th page (9.81) but somehow I'm missing on the first posting of it on the 11th page. If you are just doing the copy and paste thing only one way for a name to disappear.
No biggy, only a list.
DUSTER44T
Re: new Moparts fastest car list, post yours! [Re: BENCHRACER] #12862
05/16/05 03:11 PM
05/16/05 03:11 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
moparjohn-new all time best E.T. 9.93 at 132.97mph
1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet.440 .030 over stock crank with mild port Indy SR heads. Has 8 3/4 rear with Cal Tracs 10.5 tires all horsepower!
Re: new Moparts fastest car list, post yours! [Re: moparjohn] #12863
05/17/05 02:05 PM
05/17/05 02:05 PM
Indiana
MFR440 Offline
MFR440  Offline
Indiana
-6 second Zone --
--7 second zone ---
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
I added myself "mfr440" and moparjohn. I also put a couple others in the proper order.
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12864
05/17/05 05:05 PM
05/17/05 05:05 PM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
w8 415 71 cuda 3308lbs leafs dots 9.79 at 137.60 1.380 60ft on the back tires.
75 duster 440 in the works
71 pro street cuda
Re: new Moparts fastest car list, post yours! [Re: MFR440] #12865
05/18/05 06:17 PM
05/18/05 06:17 PM
gregsdart Offline OP
-6 second Zone --
--7 second zone ---
9.14 147mph, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.79 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12866
05/19/05 09:31 AM
05/19/05 09:31 AM
thanks greg, you da man
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12867
05/19/05 06:08 PM
05/19/05 06:08 PM
Stratford nj
cudadan Offline
cudadan  Offline
Stratford nj
I got my new best 11.702 @113.85 mph and 60ft's 1.565 in a 74 cuda 360 auto not sure of the new weight yet. Best before was a 12.02 @110
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12868
05/23/05 11:01 PM
05/23/05 11:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
10.091 @131.97 MPH.W/ 1.41 60.FT. 72 DART 3200+ LBS.all motor home ported e/heads IN THE HEAT THUMPERDART!!!!!!!
Re: new Moparts fastest car list, post yours! [Re: Thumperdart] #12869
06/05/05 11:09 PM
06/05/05 11:09 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've been working the bugs out of my 69 dart and finally broke into the 10.70's with a 10.77 @ 123.9 and a 1.49 60 ft. I think it might have pulled the wheels...hehehe. Thats at 3100 ft air density...it was hot today. Now if I could just win a round...lol.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: new Moparts fastest car list, post yours! [Re: 69dart] #12870
06/05/05 11:51 PM
06/05/05 11:51 PM
NC
HMcCandless_Jr Offline
NC
In 1993 I had a Dragster with a 540 Indy motor with 1 1050 it ran 741 180.01.
The same year I drove a 1993 Daytona at the Mopar Nationals and ran 8.39 and won the Eliminator. The motor was a 500 inch Indy with one 1050. The car was 2400lb with me in it.
Herb McCandless Jr.
Took 10 years off and Im back. Im leading the points at my local track and running it in Stock Elim. in IHRA
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12871
06/10/05 07:25 AM
06/10/05 07:25 AM
-6 second Zone --
--7 second zone ---
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
10.09 @131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12872
06/10/05 10:25 PM
06/10/05 10:25 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
-6 second Zone --
--7 second zone ---
9.172 @ 146.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy,
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: new Moparts fastest car list, post yours! [Re: nhramark] #12873
06/11/05 01:28 PM
06/11/05 01:28 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
-6 second Zone --
--7 second zone ---
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
87 dakota 6.1 hemi
