When Should The Distributor Be Locked Out?
#1285272
08/14/12 01:21 PM
08/14/12 01:21 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Trying to find the best tune for my Motor 493 stroker with 250/260 @.020 and 630 int and ex lift solid roller . When is it recommended to lock out the advance , Eng seems to like a lot of advance , currant set up is initial timing @ 24 and 10 to 12 deg mechanical all in by 2000 rpm. This is a 4 speed heavy b-body car. Wondering if i should just do away with the mechanical advance and just set it to 34 or 36 deg locked down? What advantage or disadvantage would this cause? Thank you in advance for all advice Cj.
1969 Dodge Charger
1969 Dodge Superbee
Re: When Should The Distributor Be Locked Out?
[Re: cjs69mope]
#1285273
08/14/12 01:56 PM
08/14/12 01:56 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Looks like you have a streetish cam, probably no need for you, from my exp. anyway. My 12.5 383 with 275@.050 needs lots just to run, but I still eneded up putting 6* back into the dist. locked out can be hard on pistons/pins/bearings, esp on street gas.
[Re: RemCharger]
#1285274
08/14/12 01:59 PM
08/14/12 01:59 PM
Triple Threat
Renton Washington
My 390" small block 263/268 @.050 cam
I have 16* cranking, 25* at idle, 34* all in by 2500.
[Re: cjs69mope]
#1285275
08/14/12 02:46 PM
08/14/12 02:46 PM
Thumperdart
State of confusion
My 12.1 comp. 470 is locked out at 34 degrees and have no issues but, I run two bad-ass gel batteries which seems to help..........
[Re: cjs69mope]
#1285281
08/14/12 03:45 PM
08/14/12 03:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you get to a point where your only at about 5* in the advance then go ahead and lock it out... but a good curve is better IF you need it but it has to be tuned in for your set up
[Re: RemCharger]
#1285284
08/17/12 12:27 AM
08/17/12 12:27 AM
Posts: 3,421 Toronto
mshred
Toronto
Looks like you have a streetish cam, probably no need for you, from my exp. anyway. My 12.5 383 with [Email]275@.050[/Email] needs lots just to run, but I still eneded up putting 6* back into the dist. locked out can be hard on pistons/pins/bearings, esp on street gas.
When you say that locking out is hard on bottom end parts, is that upon initial start up only? or at lower rpm's as well? Lower octane compounds these problems?
My cam is 240/248 at .050". Used to have the MP electric dizzy, swapped in a lean burn one locked out to 36 total. I have a Mallory hyfire 685 box, and I have all ten degrees of programmable start retard on currently, and the car starts fine. Two things that changed though was the car idles smoother (not sure the science of this) and it seems at lower rpms at part throttle acceleration that the car sometimes has a very slight surge.
My main reason for locking it out was for when i run the nitrous
