OK to mill intake surface of heads 0.04" ??? #1284683
08/13/12 04:13 PM
08/13/12 04:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is it OK to mill the intake side of a set of 308 small block heads 0.04"???
I dont want to mill the intake since it is brand new and might use it on a later date on an engine with brand new heads, or might swap to aluminum heads...
....Id rather mill the heads now.
Is 0.04" safe???
Re: OK to mill intake surface of heads 0.04" ??? [Re: domingo] #1284684
08/13/12 04:43 PM
08/13/12 04:43 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
sure. 4 grand is a piece of paper. shouldn't be a problem. just match the ports.
Re: OK to mill intake surface of heads 0.04" ??? [Re: rickraw] #1284685
08/13/12 05:23 PM
08/13/12 05:23 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
cool. thanks!
Re: OK to mill intake surface of heads 0.04" ??? [Re: rickraw] #1284686
08/13/12 05:50 PM
08/13/12 05:50 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Domingo may be mistyping, but he typed 40 thousandths, not 4 thousandths. I don't think you want to shave off 0.04"
Dennis
Re: OK to mill intake surface of heads 0.04" ??? [Re: cudaboy] #1284687
08/13/12 07:26 PM
08/13/12 07:26 PM
dogdays Offline
dogdays  Offline
40 thousandths = 1mm which is completely normal to take off, don't even think about it.
Worst thing that happens as you mill the intake face of the cylinder head is the valve cover rail starts to get too thin. I don't think you'd go there.
As far as milling the intake, you are right, don't do it unless it's a last resort.
R.
Re: OK to mill intake surface of heads 0.04" ??? [Re: dogdays] #1284688
08/13/12 08:31 PM
08/13/12 08:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
yes, 40 thou, which is aprox 1 mm
Yep, already doing it, I dont wanna butcher a perfect brand new intake.
Re: OK to mill intake surface of heads 0.04" ??? [Re: domingo] #1284689
08/13/12 08:32 PM
08/13/12 08:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks!
