Re: Caravan trans trouble
[Re: BBCoronet]
#1282845
08/12/12 02:57 AM
08/12/12 02:57 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Have a good trans man drive it to verify that is definetly it. If it is you have two options. One you can replace the trans with either a reman or new one which the new one is more money. Or you can have a good trans person overhaul it and replace the low/reverse piston and retainer along with all the seals if thats all it needs. I dont know your milage on the trans but most times if it has alot of miles you will want to do a complete overhaul while you have it apart. I would get a price on the overhaul with parts and compare to the unit. It helps alot if you know a good trans person who might give you a break. We used to get 10 to 14 hrs to do a complete overhaul and flush the cooler and that includes R & R time also. I would think replacing or overhaul will cost at least $1500 unless you can get a break. Good luck , Ron
