Page 15 of 32 1 2 13 14 15 16 17 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282510
07/20/14 05:23 PM
07/20/14 05:23 PM
MO
cdp Offline
cdp  Offline
MO
awesome progress! keep up the good work. Love the 56 chevy, one of my favorite tri-5's is the 56.
Re: my 69 rr black, pewter int and pewter painted roof [Re: cdp] #1282511
07/28/14 11:55 AM
07/28/14 11:55 AM
new jersey
Black 69 Beeper Offline OP
new jersey
I started getting the rear back together. all the drum brakes are finished and the e-brake cables are one. next will be the 3:55 posi unit. if anyone has a set of 3:55's in a 489 case they want to swap for 3:91's in a 489 case, please contact me.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282512
07/28/14 11:55 AM
07/28/14 11:55 AM
new jersey
new jersey
brakes all finished.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282513
08/03/14 05:54 PM
08/03/14 05:54 PM
new jersey
new jersey
I picked up a steer n gear firm steering box at carlisle for the car. man they painted the box with this crappy rubberized black paint that was just nasty to remove. anyway heres the stripped steering box after 2 afternoons of work cleaning the crap off.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282514
08/03/14 05:55 PM
08/03/14 05:55 PM
new jersey
new jersey
heres the steering box and the new pitman arm epoxy primed and ready to be painted.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282515
08/03/14 06:05 PM
08/03/14 06:05 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Mike just an FYI, your box should be painted a crappy gloss Black to replicate OEM.
Ron
Re: my 69 rr black, pewter int and pewter painted roof [Re: RJS] #1282516
08/03/14 09:12 PM
08/03/14 09:12 PM
new jersey
new jersey
thanks, i know i was going to paint it black but the stuff they put on it was like rubberized undercoating and it was still tacky. that's not going to cut it w/ me.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282517
08/04/14 04:33 PM
08/04/14 04:33 PM
new jersey
new jersey
steering box all finished.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282518
08/04/14 04:34 PM
08/04/14 04:34 PM
new jersey
new jersey
I took the air grabber duct work off the original hood today so i can start restoring that.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282519
08/04/14 04:35 PM
08/04/14 04:35 PM
new jersey
new jersey
original rubber seal cleaned up nicely and is still soft.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282520
08/05/14 06:33 PM
08/05/14 06:33 PM
new jersey
new jersey
Today pop's came over and helped get the doors back on and aligned so we can start doing the full quarters. we also removed the car from the rotisserie and its back on its own weight.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282521
08/05/14 06:34 PM
08/05/14 06:34 PM
new jersey
new jersey
back view
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282522
08/07/14 01:33 PM
08/07/14 01:33 PM
new jersey
new jersey
Heres something i don't think most guys think of until the end of a build. Do you door locks, handles, and door latches work properly? I found that my passenger side some mismatched clip holding the handle rod on. Both sides work and now I know all I need to do is clean and grease everything. The locks themselves will probably be changed out. Take note of the pewter interior color! I like it.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282523
08/07/14 01:34 PM
08/07/14 01:34 PM
new jersey
new jersey
all the cracks are fixed on the center of the air grabber box. some sanding , primer, and paint is next.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282524
08/29/14 02:59 PM
08/29/14 02:59 PM
new jersey
new jersey
all the cracks have been fixed as well as the mounting tabs on the air grabber box. i matched up a color and am in the process of epoxy priming the pieces.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282525
08/29/14 02:59 PM
08/29/14 02:59 PM
new jersey
new jersey
side pieces.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282526
09/11/14 05:19 PM
09/11/14 05:19 PM
new jersey
new jersey
and so it begins!
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282527
09/11/14 05:19 PM
09/11/14 05:19 PM
new jersey
new jersey
oh man!
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282528
09/11/14 05:20 PM
09/11/14 05:20 PM
new jersey
new jersey
yes the bottom will be removed too.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282529
09/12/14 06:43 PM
09/12/14 06:43 PM
new jersey
new jersey
all gone.
