Page 16 of 32 1 2 14 15 16 17 18 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282530
09/12/14 06:44 PM
09/12/14 06:44 PM
new jersey
Black 69 Beeper Offline OP
new jersey
yup, its gone
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282531
09/13/14 05:52 AM
09/13/14 05:52 AM
Germany
fc7_plumcrazy Offline
Germany
good luck with the progress
Carsten
Re: my 69 rr black, pewter int and pewter painted roof [Re: fc7_plumcrazy] #1282532
09/13/14 01:19 PM
09/13/14 01:19 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That car certainly went to the right guy!!!!
Ron
Re: my 69 rr black, pewter int and pewter painted roof [Re: RJS] #1282533
09/14/14 07:38 PM
09/14/14 07:38 PM
new jersey
new jersey
everything inside the quarter was stripped, treated, and is ready for black epoxy primer.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282534
09/25/14 04:52 PM
09/25/14 04:52 PM
new jersey
new jersey
original door jam had rust under the lip.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282535
09/25/14 04:53 PM
09/25/14 04:53 PM
new jersey
new jersey
Trimmed the nasty part and made a template.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282536
09/25/14 04:53 PM
09/25/14 04:53 PM
new jersey
new jersey
new piece tacked in.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282537
09/25/14 04:54 PM
09/25/14 04:54 PM
new jersey
new jersey
all welded.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282538
09/25/14 04:55 PM
09/25/14 04:55 PM
new jersey
new jersey
all ground down like it wasn't even fixed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282539
09/25/14 04:58 PM
09/25/14 04:58 PM
new jersey
new jersey
Notice the door jam pieces that I made. Very rarely does a car need just quarters. If i had left the work as it was done by the previous owner i would have maybe given it 6 months until either the door jam started to rust or it broke loose due to the weak metal from rust. thank god i decided to do full quarters.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282540
09/25/14 04:59 PM
09/25/14 04:59 PM
new jersey
new jersey
everything inside the quarter was stripped, surface rust was treated and it has 3 coats of epoxy primer (DP90LF) in an area where no one will ever see. But, it will never rust in there again.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282541
09/28/14 02:12 PM
09/28/14 02:12 PM
new jersey
new jersey
did a ruff fit of the quarter panel to make sure everything will be ok. pre fit the side marker light as well. so far so good.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282542
09/28/14 02:12 PM
09/28/14 02:12 PM
new jersey
new jersey
ruff fit from back.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282543
10/13/14 03:47 PM
10/13/14 03:47 PM
new jersey
new jersey
second fitting of the passenger quarter. the full quarters actually fit pretty good.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282544
10/13/14 03:49 PM
10/13/14 03:49 PM
new jersey
new jersey
next time the quarter goes on it will be on for good. it will now be removed and the prep to weld it on will happen.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282545
10/13/14 04:07 PM
10/13/14 04:07 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Nice job1 I love the colour combo! Going to be a sweet ride when your done!
Re: my 69 rr black, pewter int and pewter painted roof [Re: brads70] #1282546
10/25/14 05:40 PM
10/25/14 05:40 PM
new jersey
new jersey
heres the center of the air grabber air box all restored. it took me a while to match the color but i am happy with the result. next the sides will get epoxy sealed and color coded to match.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282547
10/30/14 09:39 PM
10/30/14 09:39 PM
new jersey
new jersey
heres the completed air grabber setup.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282548
10/30/14 09:40 PM
10/30/14 09:40 PM
new jersey
new jersey
passenger side close up
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282549
10/30/14 09:41 PM
10/30/14 09:41 PM
new jersey
new jersey
driver side close up
