440 rocker arm shaft torque specs anyone?? #1281016
08/07/12 04:15 PM
08/07/12 04:15 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Anyone know what to torque the rocker arm shaft to. Using factory equipment.
Jordan
Re: 440 rocker arm shaft torque specs anyone?? [Re: jordan91] #1281017
08/07/12 04:20 PM
08/07/12 04:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 440 rocker arm shaft torque specs anyone?? [Re: Dodgem] #1281018
08/07/12 04:30 PM
08/07/12 04:30 PM
michigan
jordan91 Offline OP
jordan91  Offline OP
michigan
Very Helpful
Thank You!!!
Re: 440 rocker arm shaft torque specs anyone?? [Re: Dodgem] #1281019
08/07/12 11:30 PM
08/07/12 11:30 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Says 25 Lb
I agree
MLR426
Re: 440 rocker arm shaft torque specs anyone?? [Re: jordan91] #1281020
08/08/12 01:58 AM
08/08/12 01:58 AM
Cab_Burge Online work
Cab_Burge  Online Work
My 1969 Dodge F.S.M. calls for 23 ft lbs, that works very well. Harland Sharp likes theres done at 35 FT Lb
