switching out hydraulic lifters brand to brand #1281012
08/07/12 03:44 PM
08/07/12 03:44 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
anyone foresee any problems from changing my lifters from comp cams to lunati's?? Should be pretty close plunger depth right? i have adjustable rockers.. having problems with comp cams not bleeding off at all and i can get a new set of lunatis right around the block ..... need to swap out fast, leaving for the nats 7am thurs......
Re: switching out hydraulic lifters brand to brand [Re: kbcuda] #1281013
08/07/12 04:01 PM
08/07/12 04:01 PM
no info on the plunger depth but I'd just go thru the cam breakin procedure again
