Re: new Moparts fastest car list, post yours!
[Re: Slingshot383]
#12794
01/08/05 10:21 PM
01/08/05 10:21 PM
398-W2 SMALL BLOCK DUSTER 9.85 @ 135
[Re: 9 Sec Phill]
#12796
01/09/05 12:58 PM
01/09/05 12:58 PM
Posts: 577 Grand Rapids, MI
11secondC
Grand Rapids, MI
12.03 @ 111, 1.72, SportFury440, '66 Fury III, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver.
[Re: 67Charger]
#12797
01/09/05 02:42 PM
01/09/05 02:42 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
--7 second zone --- 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.17 @ 163, Slingshot383, 408ci, Indy head, Alky FI, Coan 8", Powerglide, hoping for 7's w/ gear change 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone --- 9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @135mph,duster398, 398w2 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.91 @ 142mph MrSixpack, 440 cu in 906 heads 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416
---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54@124mph daredude 2933#,.590 cam 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.60@116mph,Beequick,69 superbee 6pak, 3800# 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @111mph,Sportfury440,66furyIII,466auto,Eheads,3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.43 @ 107.99, 1.70 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: gregsdart]
#12798
01/09/05 02:49 PM
01/09/05 02:49 PM
gregsdart
--7 second zone --- 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.17 @ 163, Slingshot383, 408ci, Indy head, Alky FI, Coan 8", Powerglide, hoping for 7's w/ gear change 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF ---9 second zone --- 9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @135mph,duster398, 398w2 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.91 @ 142mph MrSixpack, 440 cu in 906 heads 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416 ---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54@124mph, daredude 2933#,.590 cam 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) ---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.60 @116mph,Beequick,69 superbee 6pak, 3800# 11.62 @ 114mph,Phill,416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam ---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @111mph,Sportfury440,66furyIII,466auto,Eheads,3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.43 @ 107.99, 1.70 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: gregsdart]
#12799
01/09/05 03:47 PM
01/09/05 03:47 PM
KOS
10.50@129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.01@136 KOS Nick 73duster(not my car)446stageVI M1 1050dom 4.10gear on a dot tire @3350#.
[Re: RickRoss]
#12802
01/19/05 06:23 PM
01/19/05 06:23 PM
Posts: 2,569 Pa.
BENCHRACER
"Little Stroker"
"Little Stroker"
Pa.
Lets see if I can do this right and add myself in. --7 second zone --- 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.17 @ 163, Slingshot383, 408ci, Indy head, Alky FI, Coan 8", Powerglide, hoping for 7's w/ gear change 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF ---9 second zone --- 9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 139, 1.39 60ft (.055 over)440 w/727 all motor 3180# 73 Duster, DUSTER44T 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @135mph,duster398, 398w2 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.91 @ 142mph MrSixpack, 440 cu in 906 heads 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416 ---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54@124mph, daredude 2933#,.590 cam 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) ---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.60 @116mph,Beequick,69 superbee 6pak, 3800# 11.62 @ 114mph,Phill,416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam ---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @111mph,Sportfury440,66furyIII,466auto,Eheads,3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.43 @ 107.99, 1.70 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
DUSTER44T
[Re: dare_dude]
#12804
01/23/05 02:47 AM
01/23/05 02:47 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, pump gas 10.54 @ 124, daredude, 1968 Dart, .590 cam, 2933# 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.60 @ 116, Beequick, 69 superbee 6pak, 3800# 11.62 @ 114, Phill, 416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, Sportfury440, 66furyIII, 466, auto, Eheads, 3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#12805
01/26/05 01:40 PM
01/26/05 01:40 PM
Posts: 12,120 City of Champions
Prostock
City of Champions
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.55 @ 116 1.71 60' Prostock 68 Super Bee 3650# w/driver pump gas 11.60 @ 116, Beequick, 69 superbee 6pak, 3800# 11.62 @ 114, Phill, 416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
[Re: gregsdart]
#12806
02/01/05 02:28 AM
02/01/05 02:28 AM
67 cuda 1190s street tires391 gears 3500lbs
#12807
02/01/05 02:35 AM
02/01/05 02:35 AM
Posts: 1,868 Cali S.B
Sub95
super gas
super gas
Cali S.B
--7 second zone --- 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.17 @ 163, Slingshot383, 408ci, Indy head, Alky FI, Coan 8", Powerglide, hoping for 7's w/ gear change 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF ---9 second zone --- 9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 139, 1.39 60ft (.055 over)440 w/727 all motor 3180# 73 Duster, DUSTER44T 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @135mph,duster398, 398w2 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.91 @ 142mph MrSixpack, 440 cu in 906 heads 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416 ---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, pump gas 10.54 @ 124, daredude, 1968 Dart, .590 cam, 2933# 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) ---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.55 @ 116 1.71 60' Prostock 68 Super Bee 3650# w/driver pump gas 11.60 @ 116, Beequick, 69 superbee 6pak, 3800# 11.62 @ 114, Phill, 416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam ---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, Sportfury440, 66furyIII, 466, auto, Eheads, 3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', sub95 63fury 4dr street trim 452 60'2.0 12.32@112.43 Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: Sub95]
#12808
02/01/05 10:55 AM
02/01/05 10:55 AM
67Charger
Erda, UT
--7 second zone ---
11.9? @ ???, hott67cuda, 67 cuda, street tires, 3.91, 3500#
12.305 @ 112, 1.88 60', Jon Smith, 69 Charger, 493" full street trim, 7.94 @ 90 1/8
12.32 @ 112.43, 2.0 60', sub95, 63fury 4dr, street trim, 452"
[Re: 67Charger]
#12809
02/16/05 03:11 PM
02/16/05 03:11 PM
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.50 @ 115 junkyardfish '66 Barracuda 360 3270# 11.55 @ 116 1.71 60' Prostock 68 Super Bee 3650# w/driver pump gas 11.60 @ 116, Beequick, 69 superbee 6pak, 3800# 11.62 @ 114, Phill, 416 w2, 69 fb Cuda, pumpgas! 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam 11.9? @ ???, hott67cuda, 67 cuda, street tires, 3.91, 3500#
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, Sportfury440, 66furyIII, 466, auto, Eheads, 3960# 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith, 69 Charger, 493" full street trim, 7.94 @ 90 1/8 12.32 @ 112.43, 2.0 60', sub95, 63fury 4dr, street trim, 452" 12.393 @ 108.432, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
-------------------- 12.393 @ 108.432
#12810
02/17/05 11:57 PM
02/17/05 11:57 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, pump gas 10.54 @ 124, daredude, 1968 Dart, .590 cam, 2933# 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.70 @ 125mph,10secGTX, 1.50 60 ft 3700# muffs,9 inch slicks 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.99 @ 121,1.48 60',GTSport,69Dart,365,308heads
[Re: DavidDean]
#12812
03/05/05 04:50 PM
03/05/05 04:50 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
---9 second zone --- 9.11 @ 148.85, Megadart, 422" W5 sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 139, 1.39 60ft (.055 over)440 w/727 all motor 3180# 73 Duster, DUSTER44T 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @135mph,duster398, 398w2 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.91 @ 142mph MrSixpack, 440 cu in 906 heads 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416
[Re: Sub95]
#12813
03/11/05 10:05 AM
03/11/05 10:05 AM
Posts: 34 TN
allen johnson
#1 Pro Stock Racer
#1 Pro Stock Racer
TN
