WOW I weigh that much? #1279130
08/04/12 12:55 PM
08/04/12 12:55 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
So after making some passes with my 71 RR I pulled on the scale at Raceway Park just for a look. HEMI,alum heads, full exhaust, spare tire, 3/4 tank of gas, nothing stripped and with me in it 4120. Yikes! Does that sound right?
Re: WOW I weigh that much? [Re: DANA60] #1279131
08/04/12 01:23 PM
08/04/12 01:23 PM
NJ
rth Offline
rth  Offline
NJ
That sounds correct. By the way I was at the old time drags with my R/T (just in show), your car is cool. Nice job.
Re: WOW I weigh that much? [Re: DANA60] #1279132
08/04/12 02:28 PM
08/04/12 02:28 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Well at least you have a Hemi. My 74 Satellite with a 318 weighed that much on those same scales.
Re: WOW I weigh that much? [Re: DANA60] #1279133
08/04/12 02:30 PM
08/04/12 02:30 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Sounds right, when I weighed my 73 charger bb before I put it on a diet, with me it was 4250#!!!!!!
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: WOW I weigh that much? [Re: kilroy] #1279134
08/04/12 02:34 PM
08/04/12 02:34 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
So how'd you put it on a diet?
Re: WOW I weigh that much? [Re: Runnin74] #1279135
08/04/12 02:50 PM
08/04/12 02:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have seen alot of the early 70's B-bodies crack 4000 lbs. By the way how did it run ? Ron
Re: WOW I weigh that much? [Re: 383man] #1279136
08/04/12 03:09 PM
08/04/12 03:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
most important is what times did you turn. Next time drop and jack the spare, use only 1/2 tank and remove anything else that isn't bolted down.
Coming soon!!!!
Re: WOW I weigh that much? [Re: kilroy] #1279137
08/04/12 03:20 PM
08/04/12 03:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What does it weigh after the diet?
What was the diet?
Re: WOW I weigh that much? [Re: autoxcuda] #1279138
08/04/12 07:08 PM
08/04/12 07:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Hey Ron, I was always curious, did you ever weigh your 63?
Re: WOW I weigh that much? [Re: Runnin74] #1279139
08/04/12 11:36 PM
08/04/12 11:36 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
The motor-
-Aluminum everything (flywheel, head,s water pump and housing)except block, crank, and rods
-mini starter
chassis-
-cut out crash bars from doors (18lbs of metal a piece)
-running 71 bumper (weighs half as much as 73, and that with the 73 bumperets taken off!)
-running only half the front bumper mounts
-removing bumper bumpstops from behind bumper that bolts on fender
-remove rear bumper unbolted giant crash bar off rear bumper
-removed rear bumperets
-removed anti vibe stuff off trans and floor boards
-removed floor insulation replace with tinfoil coated buble wrap (plus the insulation hold moisture on the floor and starts rust)
-replace 73 tbar mount with 71 and earlier style
-aluminum master clynd
-removing air everything (which I will proably put back on with modern smaller stuff, take stuff off put back on )
I know Im forgetting stuff because I know Ive done more. I havent reweighed it because I dont know any one with scales. Im sure aluminum rims would really help but are outside the buget.
Re: WOW I weigh that much? [Re: rth] #1279140
08/04/12 11:54 PM
08/04/12 11:54 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
I saw your car and took a look at it (you were not around), loved it! Where in Jersey are you from?
Re: WOW I weigh that much? [Re: Mr.Yuck] #1279141
08/05/12 12:03 AM
08/05/12 12:03 AM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
Had not raced in 31 years (yikes), did some time trials the week or so before, got the car in low 11's. I know it will do better if I can get some traction. This Nostalgia Show was the best time (no new stuff allowed).
I'll run again at the Mopars at Englishtown.
Re: WOW I weigh that much? [Re: DANA60] #1279142
08/05/12 01:55 AM
08/05/12 01:55 AM
NJ
rth Offline
rth  Offline
NJ
I'm in Parlin. 15 minutes north of track. See you at the Mopar show.
Re: WOW I weigh that much? [Re: DaytonaTurbo] #1279143
08/05/12 11:27 AM
08/05/12 11:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes I have as with me in it and the rollbar it was a tad over 3700 lbs.
Dana60 what is your combo if you dont mind me asking ? Low 11's is plenty strong for a street car. Ron
Re: WOW I weigh that much? [Re: 383man] #1279144
08/05/12 11:35 AM
08/05/12 11:35 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Especially weighing in at 4100#.
Re: WOW I weigh that much? [Re: kilroy] #1279145
08/05/12 04:26 PM
08/05/12 04:26 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
HEMI Callis bottom, Ross 10.5 60 over 3/4 stroked=525 CI Stage V heads Engle K-8 586 lift int, 249@.5 Dur Marine Intake duel 750 Holly, TTI 2.125 TTI, 3 inch exhaust althoug I use QTP electric cutouts (open). MSD 6al Mopar Elec dist. Lupo TC, his shop did the 727, just beefed no manual reverse. Strange 60 410. 305-45-18 Nittos 555 rear, although I have the Nt-05's to use next time, Cal traks(horrible on the street, noisy!)
Re: WOW I weigh that much? [Re: DANA60] #1279146
08/05/12 05:39 PM
08/05/12 05:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Bet yah would LOVE to squeek into the 10's without yanking pieces off of it. There's a way I'm sure, what a cool ride.
Re: WOW I weigh that much? [Re: DANA60] #1279147
08/05/12 06:23 PM
08/05/12 06:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nice. What mph and 60 ft? Do you have a roll bar?
Re: WOW I weigh that much? [Re: BSB67] #1279148
08/05/12 07:09 PM
08/05/12 07:09 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
No roll bar. At ATCO they didn't seem to care at Englishtown they didn't say anything because we were in the elimination rounds I was running 11.5 for my time trials and got lower as the day went on, but my 60 was still at 1.7. Maybe some of the Jersey NY and PA people can chime in. Is ATCO a faster track then ETown? My 60 at the few time runs I made at ATCO were in the 1.6 range around 1.7 at Englishtown. I guess my weight made my ETs better then my 60 looked. MPH ranged from 118.5 to 121.5 at both places. Keep in mind, many of my runs were with little, to some, to extreme tire spin. 5800 shifts and around 6000 RPM going through the traps.
Re: WOW I weigh that much? [Re: DANA60] #1279149
08/05/12 09:32 PM
08/05/12 09:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Some tracks watch this closer than others.
I have not run at either track. Everything else equal, Atco might be faster as it is at a little lower elevation, but not much. Track prep, and the weather conditions of the day would make a bigger difference than elevation between these two.
Tire spin has a much greater effect on et than on mph. My et is a littler slower than yours, but my 60' is about 1.9. A 1.6 sixty ft. and fall Atco air and you should be dancing with 10.90s IMO.
