Re: new Moparts fastest car list, post yours!
[Re: 67Charger]
#12774
11/22/04 12:56 AM
11/22/04 12:56 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
What do you think of the re-formatting...?
---7 second zone ---
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
8.02 @ 174+, The Haze, twin turbo 452"
8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.62 @ 156.4, 1.18 60', SB412DUSTER 72 Duster, 5.33 @ 126.9-1/8, 4link B/half 2424# 412/W7 NO P/A
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.77e @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04
8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone ---
9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG
9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy,
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR
9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.972 @ 131.56, 1.350 60', Sleepyhead416
---10 second zone---
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A.
10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035#
10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380#
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.68 @ 127.38, eeka440 73 Swinger 446 906's auto
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.89 @ 121, Mopartony, 68 Dart 470cid, 727
---11 second zone ---
11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855#
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675#
11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned
11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.75 @ 113, 1.57 60', 68DART360 pump gas street tires
11.76 116.57, 1.65 60', 493Charger 68 Charger R/T auto. 493" 3750#
11.85 @ 116.6, 1.65 60', 68LAR '68 Road Runner 3926#, 4 SPEED street car
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.877 @112.52, 1.59 60', 6PKBEE Aspen R/T 360/904/3.91
11.90 @ 111.6, 1.62 60', Glen440 77 Volare 440/727/4.10
11.97 @ 111, 1.65 60', topfueldart 70 challenger 446, bone stock 906's, hyd cam
---12 second zone ---
12.02 @ 110, 1.58 60', cudadan
12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8
12.85 @ 105.43, 1.82 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Ramcharger]
#12775
11/22/04 02:40 PM
11/22/04 02:40 PM
Posts: 4,421 in a chair
mopartony
in a chair
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs a10sec70cuda, 10.40@129.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 Mopartony, 68 Dart 470cid, 727, 10.76@124 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: mopartony]
#12776
11/22/04 10:01 PM
11/22/04 10:01 PM
67Charger
Erda, UT
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
11.75 @ 113, 1.57 60', 68DART360, pump gas street tires
11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750#
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91
11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
[Re: 67Charger]
#12777
11/24/04 11:45 PM
11/24/04 11:45 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
--7 second zone ---
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#12778
11/25/04 11:26 AM
11/25/04 11:26 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
--7 second zone --- 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.62 @ 156.4, 1.18 60', SB412DUSTER 72 Duster, 5.33 @ 126.9-1/8, 4link B/half 2424# 412/W7 NO P/A 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone --- 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416
---10 second zone--- 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.85 @ 105.43, 1.82 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: gregsdart]
#12779
11/26/04 11:14 PM
11/26/04 11:14 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
10.65 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers
[Re: 11secdart]
#12780
12/05/04 01:37 AM
12/05/04 01:37 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
--7 second zone ---
9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540
[Re: gregsdart]
#12781
12/09/04 07:31 PM
12/09/04 07:31 PM
Posts: 4,675 Ortonville, MI
RoadRnnr69
Keyster
Keyster
Ortonville, MI
---11 second zone --- 11.10 @ 121.34, 1.54 60', Bubba, '80 Mirada, 440, 3855# 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675# 11.30 @ 118.98 1.60 60', TC67CUDA, 440, 346heads, 727 thru mufflers 3400# w/driver street tuned 11.317 @ 120.209, 1.542 60', Mark Gates, 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3680#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.75 @ 113, 1.57 60', 68DART360, pump gas street tires 11.76 @ 116.57, 1.65 60', 493Charger, 68 Charger R/T auto. 493" 3750# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.877 @112.52, 1.59 60', 6PKBEE, Aspen R/T 360/904/3.91 11.90 @ 111.6, 1.62 60', Glen440, 77 Volare 440/727/4.10 11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
[Re: gregsdart]
#12782
12/12/04 08:45 PM
12/12/04 08:45 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Leon Hudson 65 Barracuda KOS St. Louis 2004 #1 qualifier 8.16@165+ 3150lbs on one fogger 8.14@169 with fogger and plate both passes were mid day in the heat picture is from Bristol 2002
[Re: MegaDart]
#12783
12/20/04 10:58 PM
12/20/04 10:58 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---9 second zone --- 9.15 @ 148.85, Megadart, 422" W5 headed sb, all motor, #2540 9.189 @ 145.66, Beeracuda, 74 Barracuda @ 4241' DA 2750#, 499/PG 9.274 @ 145.76, NHRAMARK, 70 Duster 3050 lbs, 540" Indy, 9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! 9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.39 @ 144.91, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension 9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.5, MR P BODY, 395 ci W-2 2430# 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear 9.692 @ 136.2, 1.326 60', 440Jim, '69 Dart GTS, 3120#, 471 CID, ALL MOTOR 9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol 9.87 @ 138, Bigcube '69 Dart , 2950#, all motor, 11:1comp 476cid 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.972 @ 131.56, 1.350 60', Sleepyhead416
[Re: SB412DUSTER]
#12784
12/28/04 05:18 PM
12/28/04 05:18 PM
Wow, this list is gettin long..
[Re: paul69cuda]
#12787
01/01/05 11:37 PM
01/01/05 11:37 PM
67Charger
Erda, UT
---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---10 second zone--- 10.03 @ 135, paul69cuda, 69 Pro Street Cuda, w/ exhaust, D.O.T. tires 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.13 @ 135.2, 1.506 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3916# W/D, N/A. 10.18 @ 132.45, 1.394 60', ProSport, '73 Dart Sport, 451 with E-heads & MP 590 cam, 3,035# 10.18 @ 130.5 1.39 60', J-BODY, 80 Mirada, 498 Stage VI heads 3380# 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 127.38, eeka440 73 Swinger 446 906's auto 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.52 @ 107.21, 1.75 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: gregsdart]
#12788
01/02/05 02:31 PM
01/02/05 02:31 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
8.17 @ 163, 408 cubes, Indy headed, fuel injected on alcohol, Coan 8" converter, Powerglide, loafing through the lights, hoping for 7's this year with a gear change.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#12789
01/03/05 02:20 AM
01/03/05 02:20 AM
67Charger
Erda, UT
---8 second zone --- 8.02 @ 174+, The Haze, twin turbo 452" 8.17 @ 163, Slingshot383, 408ci, Indy head, Alky FI, Coan 8", Powerglide, hoping for 7's w/ gear change 8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34, 8secDart,1968 DART, 3,540#, 10.5 ET streets, real street driven car 8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
---12 second zone --- 12.02 @ 110, 1.58 60', cudadan 12.07 @ 108, 1.72 60', Mikesduster, 72 duster, 340, street trim 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith 69 charger 493" full street trim, 7.94 @ 90 1/8 12.43 @ 107.99, 1.70 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
[Re: gregsdart]
#12790
01/04/05 04:06 AM
01/04/05 04:06 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Old combo std 440 with home ported 906 heads 9.91 and 142 mph. Leagal SS combo 3700 pounds 10.38 and 130 mph.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
