1968 power steering bracket with A/C #1278911
08/04/12 01:36 AM
08/04/12 01:36 AM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
Does anyone have pics of 1968 power steering mount for an A/C C body. I have everything mounted but it looks like I may be missing a bracket to help support the power steering pump. I have the two bolts into the water pump and the single bolt that puts the two pieces together. I tensioned the belt and the pump flexs. Any ideas?
thanks
Re: 1968 power steering bracket with A/C [Re: hvyweight] #1278912
08/04/12 09:17 AM
08/04/12 09:17 AM
IN
ahy Offline
ahy  Offline
IN
The attached link/pic for Bouchillon's re-pop bracket may help. If you browse around the site, you can probably find a pic installed also.
http://bouchillonperformance.com/BPEPowerSteering.asp
