few?? about setting up holley 650dp for tunnel ram.Upda
#1278885
08/04/12 12:16 AM
08/04/12 12:16 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: few?? about setting up holley 650dp for tunnel ram
[Re: mopar65]
#1278886
08/04/12 01:46 AM
08/04/12 01:46 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
I always take the 50 CC pumps off and convert them back to 300 CC, adjusted properly 30 CC is all any single carb. motor should need, DP have two and tunnel rams have four Make sure you get all four cams the same color and location, I would start in the number one hole and go from there How much humidity is there where you race? I like small squirters,#28,31 and 32 or33 after learning I can make a motor have a starting line bog from having to much squirter,to big Do your carbs have power valves? If so check the idle vacume in gear and install a power valves rated 1 to 2 inches lower in vacume so you can keep the part throttle mixture lean and clean in the pits
[Re: Cab_Burge]
#1278887
08/04/12 01:09 PM
08/04/12 01:09 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Well, I went the other way, but on a pure race engine, 50cc pumps all around, convert the carbs to 4-corner idle circuits, get the Dominator style secondary idle speed adjusting arms, and plug the power valves. On a race motor, big cam lots of overlap, a tunnel ram has a real bad vacuum signal.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1278888
08/04/12 02:53 PM
08/04/12 02:53 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I mill the air horns off,block the power valves and sq jet 78-80 set the 4 mixture screws @ 3/4 turns out each.If you are running a trans brake no need to worry about the squirters.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: mopar65]
#1278890
08/05/12 01:05 PM
08/05/12 01:05 PM
Slingshot383
St. Charles, MO.
Any good carb shop can do it, actually you can do it yourself, it's not that hard. You do need a pair of primary metering blocks for that series of carb, match drill a couple of holes, and your done. Oh yeah, one more item, the air bleeds need to be installed on the secondary side.
