My 440 block has been decked. I am not exactly sure how much, but I did have to use the "shorter" timing chain setup. The 906 heads may or may not have been milled over the 44 years. The stock aluminum sixpack intake will not drop down far enough to get all the bolts started, even without the bathtub gasket. Obviously, the intake needs to be milled. My question: is there an easy way to determine how much should be milled, and is there any validity to a post that I once read that these early Edelbrock six pack intakes were actually milled at the wrong angle from the factory. BTW the intake is 1970.
