B-Van brake booster interchange? #1278649
08/03/12 02:12 AM
08/03/12 02:12 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
The booster in my '95 Van is about dead. push the pedal past a certain point and it starts hissing and the motor starts running bad.
There are two later ones in the local yard. One is a '98 and the other a 2000. They both have the later airbag dashes.
Will the boosters interchange? I know the maters are different too but the bolt spacing looks the same.
Hoping one will work so I dont have to spend a fortune replacing it with a new one.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: B-Van brake booster interchange? [Re: MoPar Jamie] #1278650
08/03/12 12:57 PM
08/03/12 12:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rock Auto says 90-98 interchange.
- Stu Harmon
