440 oil filter question??? #1278196
08/02/12 01:41 PM
08/02/12 01:41 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
The belt for my power steering pump is rubbing on the oil filter. Does anyone know what brand, part number oil filter to get to eliminate this problem. i need a shorter oil filter. anyone else with a 440 come accross this problem? thanks for the help.
Re: 440 oil filter question??? [Re: mkbubs] #1278197
08/02/12 01:43 PM
08/02/12 01:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What year car ?
The filter length is not your problem
Re: 440 oil filter question??? [Re: mkbubs] #1278198
08/02/12 01:49 PM
08/02/12 01:49 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Use a Fram PH43 or equivalent.
Re: 440 oil filter question??? [Re: JohnRR] #1278199
08/02/12 01:57 PM
08/02/12 01:57 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
'70 dodge coronet
Re: 440 oil filter question??? [Re: mkbubs] #1278200
08/02/12 03:09 PM
08/02/12 03:09 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
PH43 is the Fram ( ) number for the shorty version of the PH8A.
However, I'm with John; the filter length isn't your problem and I'm not sure a PH43 would be short enough anyway.
I'm thinking, wrong belt, wrong pulley or something wacky with the brackets.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440 oil filter question??? [Re: JohnRR] #1278201
08/02/12 03:14 PM
08/02/12 03:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I agree with John. The brackets, pulleys, belt or all of the above are likely incorrect. Are they stock parts or some aftermarket abomination?
edit: I just got treed by DPelletier. Took too long thinking about it.
Re: 440 oil filter question??? [Re: GomangoCuda] #1278202
08/02/12 03:31 PM
08/02/12 03:31 PM
DPelletier Offline
DPelletier  Offline
YES!! for the WIN!!
Re: 440 oil filter question??? [Re: DPelletier] #1278203
08/02/12 03:58 PM
08/02/12 03:58 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
85068 at CarQuest for the shorty.
I think the Wix label brand numbers are the same on the end of that string. They make those filters for CQ and NAPA.
85515 is the long filter for early power steering or manual steering.
I want my fair share
Re: 440 oil filter question??? [Re: SomeCarGuy] #1278204
08/02/12 04:38 PM
08/02/12 04:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stay far far away from fram unless you like rebuilding your engine.
Re: 440 oil filter question??? [Re: stumpy] #1278205
08/02/12 04:53 PM
08/02/12 04:53 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
When will this internet based fairy tale end? I have over a half million miles and 4-500 bracket racing passes on Frams,never a failure.
Re: 440 oil filter question??? [Re: formula_s] #1278206
08/02/12 05:26 PM
08/02/12 05:26 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i guess cardboard makes a decent filter?
Re: 440 oil filter question??? [Re: 05dakota] #1278207
08/02/12 05:33 PM
08/02/12 05:33 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Saves weight !!
Re: 440 oil filter question??? [Re: 62maxwgn] #1278208
08/02/12 05:34 PM
08/02/12 05:34 PM
JohnRR Offline
JohnRR  Offline
Saves weight !!
Re: 440 oil filter question??? [Re: formula_s] #1278209
08/02/12 06:50 PM
08/02/12 06:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
at least not everybody here is drinking the kool-aid, . i've used my last wix due to drain back. same with k&n's. going back to baldwins in the old cars. never had an issue with purolators. come to think of it i've never had an isuue with FRAM.
Re: 440 oil filter question??? [Re: lewtot184] #1278210
08/02/12 07:20 PM
08/02/12 07:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sorry but the Fram cardboard filters is not an internet fairy tale. It is the fact. Use them at your own risk. Some people have had no problem with them but I won't risk one of my high dollar motors on them. When you're shifting at 6500 rpm you don't want to trust cardboard junk filters. Take a Fram apart and then tell me how well made they are.
Re: 440 oil filter question??? [Re: stumpy] #1278211
08/02/12 07:32 PM
08/02/12 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cardboard end plates do not make "cardboard filters". All the end plate does is center the filter element.
Re: 440 oil filter question??? [Re: John_Kunkel] #1278212
08/02/12 07:34 PM
08/02/12 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Until they deteriorate and then centering goes down the tubes along with your engine.
Re: 440 oil filter question??? [Re: John_Kunkel] #1278213
08/02/12 08:11 PM
08/02/12 08:11 PM
DPelletier Offline
DPelletier  Offline
Use whichever one gives you the "warm and fuzzies".
or
Re: 440 oil filter question??? [Re: DPelletier] #1278214
08/02/12 08:14 PM
08/02/12 08:14 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Wix/Napa Gold filters (and others, that's just what I like) use better parts and better construction. If you cut them apart next to a Fram there's absolutely no question and no reason not to spend the extra few dollars.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 440 oil filter question??? [Re: DPelletier] #1278215
08/02/12 08:16 PM
08/02/12 08:16 PM
DPelletier Offline
DPelletier  Offline
...this one;
do you REALLY need to see anything else?
