Re: 440 oil filter question???
[Re: JohnRR]
#1278199
08/02/12 01:57 PM
08/02/12 01:57 PM
Posts: 61 Texas
mkbubs
Texas
[Re: mkbubs]
#1278200
08/02/12 03:09 PM
08/02/12 03:09 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
PH43 is the Fram ( ) number for the shorty version of the PH8A. However, I'm with John; the filter length isn't your problem and I'm not sure a PH43 would be short enough anyway. I'm thinking, wrong belt, wrong pulley or something wacky with the brackets. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1278203
08/02/12 03:58 PM
08/02/12 03:58 PM
Posts: 10,230 Someplace you aren't
SomeCarGuy
85068 at CarQuest for the shorty.
I think the Wix label brand numbers are the same on the end of that string. They make those filters for CQ and NAPA.
85515 is the long filter for early power steering or manual steering.
I want my fair share
[Re: formula_s]
#1278209
08/02/12 06:50 PM
08/02/12 06:50 PM
Posts: 3,916 usa
lewtot184
usa
When will this internet based fairy tale end? I have over a half million miles and 4-500 bracket racing passes on Frams,never a failure.
at least not everybody here is drinking the kool-aid, . i've used my last wix due to drain back. same with k&n's. going back to baldwins in the old cars. never had an issue with purolators. come to think of it i've never had an isuue with FRAM.
[Re: stumpy]
#1278211
08/02/12 07:32 PM
08/02/12 07:32 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Cardboard end plates do not make "cardboard filters". All the end plate does is center the filter element.
[Re: DPelletier]
#1278214
08/02/12 08:14 PM
08/02/12 08:14 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Wix/Napa Gold filters (and others, that's just what I like) use better parts and better construction. If you cut them apart next to a Fram there's absolutely no question and no reason not to spend the extra few dollars.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
