Re: went to mid michigan yesterday [Re: justinp61] #1278146
08/04/12 10:45 AM
08/04/12 10:45 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
yep. i had a 50/50 mix and no matter what i did with jetting lean or rich it made very little change. it did like more timing thou and if i would of had more time i would have put more in it. i had this happen one other time with same results,so again if it does'nt need race gas don't put it in unless you like going slow. i wasted $75 on that can of vp. lesson learned for sure this time. i also contacted moneymaker racing(where i bought my cal-tracs) and they don't like that track when the weathers hot,they can't hook there,so maybe that was my other issue. alittle dissapointed,but i'll try again at milan.
Re: went to mid michigan yesterday [Re: mopar dave] #1278147
08/04/12 11:05 AM
08/04/12 11:05 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Where do you have the bars, top or bottom hole? Preload?
Re: went to mid michigan yesterday [Re: justinp61] #1278148
08/04/12 11:42 AM
08/04/12 11:42 AM
Mt Morris Michigan
Mt Morris Michigan
set up is just as moneymaker suggested. bottom hole one flat drivers and two flats pass.
Re: went to mid michigan yesterday [Re: mopar dave] #1278149
08/04/12 11:59 AM
08/04/12 11:59 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Again, how many passes on your tires?
Re: went to mid michigan yesterday [Re: Thumperdart] #1278150
08/04/12 02:11 PM
08/04/12 02:11 PM
Mt Morris Michigan
Mt Morris Michigan
right now i have 6 passes on new tires.
Re: went to mid michigan yesterday [Re: mopar dave] #1278151
08/04/12 02:30 PM
08/04/12 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You`re good there. Car leaves and runs ok from what I could see in the video and it looks like you have about 4-5"`s of ft. travel..........
Re: went to mid michigan yesterday [Re: Thumperdart] #1278152
08/04/12 03:03 PM
08/04/12 03:03 PM
Mt Morris Michigan
Mt Morris Michigan
the fuel was my biggest enemy on that day and i kept clicking the shocks stiffer thinking the track had to be good because they kept prepping it. maybe i should have went softer because my best 60 was right off the trailer with 4-5 clicks.
