Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277352
09/11/12 04:26 PM
09/11/12 04:26 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Here is my truck that we've been discussing...
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277353
09/11/12 04:43 PM
09/11/12 04:43 PM
scratchnfotraction Offline
nice truck
thats is an ok set up for the front mount.
can you post a shot of your shackle on the rear of front leafs?
post a shot of the rear springs front and rear shackle and blocks u-bolts.
you could just add a 2" add a leaf into those front springs and they would be flat and not negative arch like now.
a main leaf from a 4x4 front with the spring eyes cut off and then stuck under your main leaf will do about the same thing for the arch.
what are you after? a slight lift or just flat front springs and stay as high as is now?
I would think it has a good ride and is not harsh as most 4x4s are close to bump stops stock.
if you have body lift make sure they stay torqued up, they tend to work loose when off roading a lot with frame flex.
again. nice looking truck.
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277354
09/12/12 02:06 AM
09/12/12 02:06 AM
mexico
dodgestrike Offline
dodgestrike  Offline
mexico
cool truck , tho I don't like the mount setup I would reverse it to the original way and put longer shackles in the rear of the front spring. also if you need new springs look at rancho or other brands that carry spring lift packs , unless you are against lift.
Re: 1980 W150 Front Leaf Springs [Re: dodgestrike] #1277355
09/12/12 03:18 AM
09/12/12 03:18 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Look closer. It appears to be welded so it doesn't pivot so its setup as stock but could have been fabed better and if kept that way a bead all the way around would be better
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277356
10/09/12 10:57 AM
10/09/12 10:57 AM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I want to eventually mount lifted springs on the front frame perch and do away with the "engineering"...
1969 Y2 Super Bee
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277357
10/10/12 03:24 AM
10/10/12 03:24 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277358
10/12/12 09:40 PM
10/12/12 09:40 PM
Boswell, PA
67PLY Offline
67PLY  Offline
Boswell, PA
Got a front 3 ply (1750# cap)spring for my '84 W100 from www.sdtrucksprings.com paid $ 76.50
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277359
10/12/12 10:27 PM
10/12/12 10:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I'll sell you some 4" lift springs
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277360
05/28/13 07:36 PM
05/28/13 07:36 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Thanx to all who responded to this post a while back. I FINALLY got some new leaf springs for the front of my truck(OEM replacement). I'm mounting the axle to the springs... but the U bolts need compressed to go back in the holes.... There's not enough room for a C clamp and I don't have big enough channel locks or anything else... anyone know a good way to squeeze the bolts together enough to get them back in the holes? Very limited space to get something on the U bolts when trying to re mount them.
1969 Y2 Super Bee
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277361
05/28/13 09:39 PM
05/28/13 09:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Set the u-bolt on a side with a spacer under it so it is not sitting on the threads. Take a hammer and strike the other side, close to the rounded part, (be careful not to damage the threads) to narrow the opening. It really does not take much of a blow, I suggest you do a little at a time.
If the opening has closed up and needs to be opened a little, grasp the u-bolt from one of the sides and strike the closed end against something solid. Again, it really doesn't take much of a blow. Strike lightly.
My shop used to be close to a spring shop that custom bent u-bolts, these words of wisdom comes directly from him, many years ago. Gene
Re: 1980 W150 Front Leaf Springs [Re: Texas383] #1277362
05/29/13 06:48 PM
05/29/13 06:48 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Wooo Hoooooo!!! I got the U bolts in and tightened down.
I beat on them. I put them in my HUGE vice and almost had the bolt ends touching. Neither made the ends stay closer together after hitting them or taking out of vice. The old bolts are tempered I guess... or something. I managed to get a C clamp on them. It wasn't easy and the clamp kept coming off but at least I was EVENTUALLY successful.
1969 Y2 Super Bee
