Carter AVS ID. H8 4615S ? #1275223
07/28/12 10:27 AM
07/28/12 10:27 AM
Indiana
68_661charger Offline OP
Indiana
The numbers letters in the front are H8 4615S. Ive always had it on a 69 383. Whats it orig for or any other info like cfm? Thank you.
Re: Carter AVS ID. H8 4615S ? [Re: 68_661charger] #1275224
07/28/12 11:40 AM
07/28/12 11:40 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
69 383 hp manual trans
i believe 625 cfm but not 100% sure on that
Re: Carter AVS ID. H8 4615S ? [Re: TONY_DAGOSTINO] #1275225
07/28/12 12:23 PM
07/28/12 12:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
correct on all accounts Tony
Re: Carter AVS ID. H8 4615S ? [Re: ScottSmith_Harms] #1275226
07/28/12 01:12 PM
07/28/12 01:12 PM
Indiana
Indiana
I appreciate that, thanks.
Re: Carter AVS ID. H8 4615S ? [Re: 68_661charger] #1275227
07/28/12 02:13 PM
07/28/12 02:13 PM
USA
big-block-dave Offline
USA
H8...Carb built August 1968
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
