Tires-How wide can I go #1275068
07/27/12 06:58 PM
07/27/12 06:58 PM
Sierra Vista, Arizona
E
extranjero Offline OP
E
How big of a tire can I stuff in the rear of a 1967 Belvedere before rubbing becomes a problem. Thanks in advance.
Re: Tires-How wide can I go [Re: extranjero] #1275069
07/28/12 12:19 AM
07/28/12 12:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If you use a tape measure you will find out exactly what your car can handle. Some cars have rearends that have the spring plateswelded on that are not in the proper place. You might pick a wheel/tire combo that will fit 1 side but not the other..
I am truckless..
