Page 5 of 25 1 2 3 4 5 6 7 24 25
Re: new Moparts fastest car list, post yours! [Re: Bubba] #12714
09/23/04 10:30 AM
09/23/04 10:30 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
will someone stick mine where it belongs...
b3422w5
70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: new Moparts fastest car list, post yours! [Re: Bubba] #12715
09/23/04 10:55 AM
09/23/04 10:55 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Done
---7 second zone ---
572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60'
valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
The Haze 8.02 @ 174+ twin turbo 452"
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164
TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340#
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04
RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF
---9 second zone ---
Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG
NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph
TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension
MR P BODY 9.47@142.5 395 ci W-2 2430#
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID
Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor
b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99
---10 second zone ---
Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A.
J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam
StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor.
daron 73 duster 10.50 et @ 127.00 sb street car
BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
eeka440 73 Swinger 446 906's auto 10.84@124.4
---11 second zone ---
Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS
ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60'
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto
w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver
mark gates e.t.:11.404 speed: 120.887 3765# 1.569 sixty
440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires
topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
---12 second zone ---
cudadan, 12.02 at 110 with a 1.58 60ft
quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4
Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60')
Re: new Moparts fastest car list, post yours! [Re: Bubba] #12716
09/23/04 03:25 PM
09/23/04 03:25 PM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
7 second zone ---
TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned
---13 second zone ---
Re: new Moparts fastest car list, post yours! [Re: RT540] #12717
09/23/04 03:29 PM
09/23/04 03:29 PM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
One more time
Re: new Moparts fastest car list, post yours! [Re: TC67CUDA] #12718
09/24/04 01:37 PM
09/24/04 01:37 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: new Moparts fastest car list, post yours! [Re: OUTLAWD] #12719
09/24/04 06:26 PM
09/24/04 06:26 PM
Connecticut
biginchmotor Offline
Connecticut
Can someone put this on the list for me...thanks, John. 72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 mph at the Englishtown Mopar show in June...thanks.
Re: new Moparts fastest car list, post yours! [Re: OUTLAWD] #12720
09/25/04 04:49 AM
09/25/04 04:49 AM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
mark gates e.t.:11.404 speed: 120.887 1.569 sixty 451/727/3.91 #3765 AMC Pacer
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12721
09/26/04 08:37 AM
09/26/04 08:37 AM
pa
572charger Offline
572charger  Offline
pa
hey some one stick me on there !!
572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: new Moparts fastest car list, post yours! [Re: 572charger] #12722
09/26/04 09:40 AM
09/26/04 09:40 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Post deleted by Defbob [Re: Plumb Wired] #12723
09/26/04 10:29 AM
09/26/04 10:29 AM
Re: new Moparts fastest car list, post yours! #12724
09/26/04 05:32 PM
09/26/04 05:32 PM
, PA
sleepyhead416 Offline
, PA
It was on here now it's gone.
Re: new Moparts fastest car list, post yours! #12725
09/26/04 07:55 PM
09/26/04 07:55 PM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
Time to bump me up a couple spots...
hemifred single turbo road runner 7.21 @ 193 mph 1.11 60' 1/8th 4.56 @ 156 mph
hemifred SOX&MARTIN HEMI DUSTER 8.781 @ 154.16 mph 1.261 60' all motor
TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned mark gates AMC Pacer 11.33 @ 120.087 1.55 60' #3765 iron head 451/727/3.91
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12726
09/27/04 10:01 AM
09/27/04 10:01 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I'm having trouble putting mine on and not messing up someone else,can someone help me? 77 Aspen R/T 360/904/3.91 60'@ 1.59 11.87@112.52
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12727
09/27/04 10:49 AM
09/27/04 10:49 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Max-Maniac 64 Dodge Max Wedge. 10.85 @ 121.2 1.50 60'
Re: new Moparts fastest car list, post yours! [Re: max_maniac] #12728
10/02/04 03:28 PM
10/02/04 03:28 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
67Charger, 12.854 @ 105.48, '67 Charger, 440/727 (original), 4.10's 3800#
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12729
10/03/04 06:25 AM
10/03/04 06:25 AM
gregsdart Offline OP
Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142
Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
---10 second zon1.350 60FT 9.972 E.T 131.56 MPH
6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12730
10/03/04 11:59 AM
10/03/04 11:59 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12731
10/03/04 08:49 PM
10/03/04 08:49 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid
---10 second zone---
A new best
Re: new Moparts fastest car list, post yours! [Re: Bigcube] #12732
10/03/04 10:04 PM
10/03/04 10:04 PM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
I can't seem to get mine in without screwing up someone else's post either. Another new best: Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4. Will someone help?
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12733
10/06/04 01:38 PM
10/06/04 01:38 PM
85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off)
Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
