Car wont stay running #1271706
07/21/12 10:54 PM
07/21/12 10:54 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Went to a car show today.Car was almost out of gas so I stopped and put 10 gallons in.Drove 25 miles with the AC on,car raan fine.Sat at the show all day,left,fired right up,came home 25 miles.4 hours later ,drove 3 miles to the store and when I got there it died like it was loading up.When I hit the key it would emediatly fire then die.It did it like 10 times and I limped it home.Died twice but fired right back up.Made it to the garage but could not back it in.It fires but wont stay running.There is a wierd burning smell like its rich??Bad gas??I have never put a fuel filter on in the 10 years I have owned it..I will change it tomorrow and see if that helps but its got me stumped???
Re: Car wont stay running [Re: 70RR383] #1271707
07/21/12 11:19 PM
07/21/12 11:19 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Just went back out to the garage and there is a wierd burnt smell throughout the garage.Almost like a clogged cat smell???
Re: Car wont stay running [Re: 70RR383] #1271708
07/21/12 11:24 PM
07/21/12 11:24 PM
I'd start with a good visual & see if you spot anything obvious such as a burnt wire
Re: Car wont stay running [Re: RapidRobert] #1271709
07/22/12 12:09 AM
07/22/12 12:09 AM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
Possibly a ballast going bad if you're running one?
