Page 9 of 12 1 2 7 8 9 10 11 12
Re: Keisler SS 700 [Re: relax383] #1271189
04/22/13 06:42 AM
04/22/13 06:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just ordered a plasma cutter to make the trans crossmember surgery easier. My next project is getting a 518 trans into another '69 Coronet 500.
Re: Keisler SS 700 [Re: 451Mopar] #1271190
04/22/13 08:13 PM
04/22/13 08:13 PM
Solon, Oh
Convertible Bee Offline
Solon, Oh
sorry been away for a while,
Haven't driven the my bee with ss700 yet, my engine block froze and cracked over winter,found that when I was putting in a new rear main seal, so it's new block time, shop told me a few weeks due to their work load... 2nd week in May if I'm lucky...
anyway can't win 'em all...
I'll post more when I know more, too note, I'm gonna pound that ss700 with the new engine "535cid"...
Re: Keisler SS 700 [Re: 451Mopar] #1271191
04/23/13 10:36 PM
04/23/13 10:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So let me get this straight,you need a plasma cutter,Bridgeport,and a lathe to make this "no hack job" "bolt in" transmission fit
Keisler Sucks and Passon rules Rah Rah Rah...that's for Gayclona
I guess Shafti thinks your time is worth nothing letting you guys do all the fitting while he counts the money
Gus
64 Plymouth Savoy
Dana 60
Re: Keisler SS 700 [Re: fourgearsavoy] #1271192
04/24/13 01:07 AM
04/24/13 01:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Gus
No, most could be done with a sazzall or wizz wheel
Re: Keisler SS 700 [Re: 451Mopar] #1271193
04/30/13 04:05 AM
04/30/13 04:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Crossmember clearanced for tailshaft and floor cur for shifter/shifter top plate clearance.
Re: Keisler SS 700 [Re: 451Mopar] #1271194
04/30/13 04:15 AM
04/30/13 04:15 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I boxed in the cut out part with 3/16" thick strap.
Can't find that photo, but here is the trans installed at the angle/position Keisler expects (5" from the top of the trans tunnel.)
Re: Keisler SS 700 [Re: 451Mopar] #1271195
04/30/13 04:19 AM
04/30/13 04:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
This is the height it should be, about 3.25" to 3.5" from the top of the tunnel.
Re: Keisler SS 700 [Re: 451Mopar] #1271196
04/30/13 04:24 AM
04/30/13 04:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
At the 5" drop from the trans tunnel, this is the lack of clearance to the passenger side TTI header.
Not shown, oil pan clearance was about 1/2"
Re: Keisler SS 700 [Re: 451Mopar] #1271197
04/30/13 04:31 AM
04/30/13 04:31 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just a pic from when I was painting the 1-1/2" x 3" crossmember spacer (and longer bolts) we made to move the trans up. The spacer sits flat, this was on end just to paint it. We also hacked the front drivers side of the trans crossmember to try making more room for the speedometer cable roting, and we added a reinforcing washer. Speedometer cable clearance is still tight. I though I took more pictures, but I think the battery may have died?
Re: Keisler SS 700 [Re: 451Mopar] #1271198
05/07/13 04:29 AM
05/07/13 04:29 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
great information keep the pics coming.
Re: Keisler SS 700 [Re: relax383] #1271199
05/07/13 04:56 AM
05/07/13 04:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Was hoping to have the driveshaft, been two weeks since I sent Keisler the length. Maybe I'll get it this week .....
Re: Keisler SS 700 [Re: 451Mopar] #1271200
05/19/13 04:51 AM
05/19/13 04:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Got the driveshaft this week, so today (ok Saturday) I dialed in the bellhousing with the 0.021" offset dowels, Installed the roller pilot bearing (easy), Installed the clutch and pressure plate, and went to install the throwout bearing, and ran into the first issue of the day. The bearing retainer/shaft the throw out bearing rides had a black parkerized type finish, and the throwout bearing was just grabbing it and wouldn't slide on. Took some emery cloth and polished up the input bearing retainer shaft, and the throw out bearing and that fixed that problem. Filled the trans with ATF (Mercron/Dextron per the instructions), and installed the trans which took a bit of time. Need to put the throwout bearing on the clutch fork BEFORE installing the trans (my bad), but got the trans in and all bolted up.
The driveshaft fit very good, and finished up a bunch of the small stuff which took more time than I care to admit (installing the carpet, speedometer cable, reverse light wiring, gas pedal, seats, exhaust, starter, etc...
Took the car out for a quick drive to the gas station and short drive (maybe 10-miles.) The trans shifts really nice, was quiet, and no vibrations (on went upto 70-mph.) I did have an issue where the trans would come out of 5th gear when coasting down around 40 mph? Above 40 and no problem. I will pull the console cover/boot and re-check in case the boot is trying to pull it out of 5th?
Anyhow, need to put more easy miles on it and the clutch before I can hammer on it.
Re: Keisler SS 700 [Re: 451Mopar] #1271201
05/29/13 09:45 PM
05/29/13 09:45 PM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
Did you find out why it was popping out of gear?
Re: Keisler SS 700 [Re: 451Mopar] #1271202
05/29/13 10:07 PM
05/29/13 10:07 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
any updates that you can give? i'm watching this thread closely. i need a few overdrive units for my cars.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Keisler SS 700 [Re: Old School] #1271203
05/30/13 02:20 AM
05/30/13 02:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Last week I drove the car, but did not get a chance to work on it. I need to remove the console top and make sure the shifter boot or carpet is not causing the problem? I called Keisler and they were nice, said they would take care of the problem if it is not one of the things above (I forgot to double check the carpet clearance.)
The transmission shifts really nice, so once the fifth gear issue is solved I will be happy with the transmission, and the clutch seems to work way better than my old one. Got on it getting onto a highway and smoked the tires through first, chirped the tires on the 1-2,2-3, and 3-4 shifts
I guess if you installed the trans with the tail tilted down it would fit without cutting the trans tunnel (still need to cut for the shifter.)
My other non-trans issue is the stock tach won't work with the Crane HI-6 ignition...
Re: Keisler SS 700 [Re: 451Mopar] #1271204
06/10/13 07:37 AM
06/10/13 07:37 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
I am getting ready to order my trans any more advice from you guy who have done the conversion? I was planning to order the trans and their bellhousing any TO bearing issues i should watch for?
Re: Keisler SS 700 [Re: relax383] #1271205
06/11/13 02:58 AM
06/11/13 02:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm using the factory mechanical setup, and it has been working good. I don't know about the hydraulic clutch setup?
Re: Keisler SS 700 [Re: 451Mopar] #1271206
06/11/13 01:20 PM
06/11/13 01:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If the hydraulic set up supplied is the FTE throw out bearing, and the Keisler/Wilwood master, it's a very reliable set up, I've installed quite a few units, my only suggestion is to cover the braided stainless line that runs to the hyd TOB with a high heat spark plug wire covering, esp if running headers, as the braided line like to absorb heat, I usually run Porsche Blue Racing fluid in the hyd TOB as it has a high heat rating, and thicker viscosity than conventional DOT3-5 brake fluid
Mike
Re: Keisler SS 700 [Re: DAYCLONA] #1271207
06/12/13 09:21 AM
06/12/13 09:21 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
thanks for the advice Mike will make a note on the Hyd Fluid.
Re: Keisler SS 700 [Re: 451Mopar] #1271208
06/20/13 09:07 PM
06/20/13 09:07 PM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
Any of you guys put a decent amount of miles on their 5 speeds yet?
