Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: vibration update on the cuda #126984
10/03/08 09:17 AM
10/03/08 09:17 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
LOL i'll be hoping for good ones
Re: vibration update on the cuda [Re: cudadan] #126985
10/06/08 05:42 PM
10/06/08 05:42 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well i took the D/S out and put in a slip yoke, put a block of wood behind it, and ran it through the gears and no vibes at all, smooth as glass. so now its back to the D/S back. now since i changed everything there is where do i start? do i start changing everything all over again? i am gonna look at the pearches to make sure there are no cracks. i do have anew tranny mount that im gonna put it just for the hell of it too
Re: vibration update on the cuda [Re: cudadan] #126986
10/06/08 06:43 PM
10/06/08 06:43 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would take the shaft into a driveshaft shop and have them check it out completly, then I would take it to another one and get a 2nd opinion.
68 Barracuda Formula S 340
Post deleted by Defbob [Re: Bad340fish] #126987
10/06/08 06:53 PM
10/06/08 06:53 PM
Re: vibration update on the cuda #126988
10/06/08 07:17 PM
10/06/08 07:17 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Dan Tony Gambardella did my shafts and are fine
whats he charge over there, i've gotten ptices from everyone and the prices are all over the place lol
Re: vibration update on the cuda [Re: cudadan] #126989
10/06/08 07:55 PM
10/06/08 07:55 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
well you can narrow it down to the drive shaft, rear or springs.
you said you never touched the springs....right?
Re: vibration update on the cuda [Re: DJVCuda] #126990
10/06/08 08:00 PM
10/06/08 08:00 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
yeah never touched'em, i put the pinion angle back down to 5.7 down cause thats where its always been. took it out for a ride and i still feel the vibes, even with a new tranny mount too. i'd go with super stock springs but i don't want my car to look likes it ready to go off road cause how high they sit lol, im gonna sand blast my other rear housing and put that in when i get a chance, maybe it could be bent or something.
Re: vibration update on the cuda [Re: cudadan] #126991
10/07/08 01:49 AM
10/07/08 01:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would just junk the shaft you have and buy a new one from a reputable builder...But what do I know
Re: vibration update on the cuda [Re: Al_Alguire] #126992
10/07/08 07:49 AM
10/07/08 07:49 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
one thing i did notice when i put the drive shaft back in there was a bout .010 to .015 side to side play where theu joint sits in the yoke.
Re: vibration update on the cuda [Re: cudadan] #126993
10/08/08 06:49 PM
10/08/08 06:49 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Read through this...
https://board.moparts.org/ubbthreads/show...e=0#Post4728051
I'm getting a new one built.
When you decide to quit, THAT is the moment when you would've succeeded..
Post deleted by Defbob [Re: cudadan] #126994
10/08/08 07:30 PM
10/08/08 07:30 PM
Re: vibration update on the cuda #126995
10/08/08 07:41 PM
10/08/08 07:41 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Re: vibration update on the cuda [Re: Leigh] #126996
10/09/08 10:20 PM
10/09/08 10:20 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Look Here for a driveshaft
just got my new chromoly yoke today, i'll have it in tomorrow, then it's driveshaft time
Re: vibration update on the cuda [Re: cudadan] #126997
10/10/08 09:10 PM
10/10/08 09:10 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well still has the vibes with the brand new yoke, guess its time to try another driveshaft, almsot forgot how many i've tried in the car lol, or i might just put a whole other rear housing in first, that wont cost me anything
Re: vibration update on the cuda [Re: cudadan] #126998
10/10/08 09:54 PM
10/10/08 09:54 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
How deep is the yoke into the trans and is the rear bushing tight? My driveshaft was 5/8 of an inch or so too short and it vibrated quite bad in the same fashion as you describe.
Don.
Re: vibration update on the cuda [Re: MoparDonny] #126999
10/11/08 07:11 PM
10/11/08 07:11 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Don.
the drive shaft that i was first using was in there for 6yrs with no issues, im gonna have one of the driveshafts checked out next week
Re: vibration update on the cuda [Re: cudadan] #127000
11/22/08 06:45 PM
11/22/08 06:45 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well i still have this issue with the vibes. how can i tell if the driveshaft is centered in the car or is it supposed to be to one side of the car more than the other? i measured from the side of the D/S to the frame on both sides and got a 2" difference, not sure if its supposed to be the same, any ideas? also i tried another driveshaft again with the same results. then i tried another center same results. i tested these with out the axles in the car, so i can eliminate all that, and still has vibes at 35mph but in reverse at the same rpm as forward there are no vibes at all smooth as glass
Re: vibration update on the cuda [Re: cudadan] #127001
11/23/08 04:40 AM
11/23/08 04:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I mensioned that you should check the rear yoke for spreading [ twice ] on page three, Why are you changing out the front yoke if its destroying the rear u-joint??? There's probably more slop than that also.You might want to try turning thr rear yoke by hand to see if the pinion goes in and out some , if it does it might be the reason it doesen't vibe in reverse
Re: vibration update on the cuda [Re: rowin4] #127002
11/23/08 10:11 AM
11/23/08 10:11 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
i did put a new billtet yoke on the rear and the ujoint is a nice tight fit now, as for the rear it self i tried another set of gears, this set is a 3.91 with the same results as the 4.30's and the 3.23's
Re: vibration update on the cuda [Re: cudadan] #127003
11/23/08 11:05 AM
11/23/08 11:05 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I had a customers duster that had a vibration problem years ago. I ended up changing all the simple stuff first. changed the tail shaft bushing, output shaft, yokes, ujoints, had the drive shaft balanced. nothing helped. I finally put one of my transmissions in it and the problem was gone. I tore down the tranyy and couldn't see anything wrong
