Measuring Camshaft Walk?
#1269886
07/18/12 03:58 AM
07/18/12 03:58 AM
Posts: 183 Charleston, SC
bronco9588
Charleston, SC
1) Where is hydraulic roller retrofit camshaft. I'm installed a thrust plate and thrust washer to control both directions of the camshaft play. I did not get a chance to check end play before installing timing chain cover. Moreover i have no idea how to do this even without chain cover installed. Anyways i wanted to explore a couple options to measure camshaft walk with the timing cover installed. The two ideas I had was to put the engine against a wall and measure the flexure of the timing cover by pushing against it with a dial gauge indicator. I believe another option might be a L shapped wire fixed to a dial gauge indicator where the L rests in the valley between two lobes. Anyways, wanted to know of any thoughts on the process.
2) Since I am using the stock stamped timing cover which is too flimsy in my opinion, I was thinking of building up some plumbers putty behind the water pump to serve as a means to resist flexure in the cover and take up any additional slop I did not account for earlier.
'73 Charger Petty Blue, Black Vinyl, and Gill Slits
727 torque-flight
400 BB Chrysler
8 3/4 rear
Re: Measuring Camshaft Walk?
[Re: BIGSTROKER]
#1269889
07/18/12 01:01 PM
07/18/12 01:01 PM
Posts: 8,899 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
i like the indy cast cover use .250 pump hsg spacers and space out the crank pulley
Overpriced and doesn't fit under the stock pump! Muscle Motors sells a VERY nice cast cover for $110. that fits under the stock pump. Thick enough to drill a hole for a pipeplug to check endplay.
[Re: BIGSTROKER]
#1269891
07/18/12 09:26 PM
07/18/12 09:26 PM
bronco9588
Charleston, SC
Any problem with using the backside of the water pump?
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: Hemi Allstate]
#1269896
07/20/12 03:10 AM
07/20/12 03:10 AM
bronco9588
Charleston, SC
Anybody shim their cover to housing gap?
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: bronco9588]
#1269897
07/20/12 09:16 AM
07/20/12 09:16 AM
Posts: 75,077 U.S.S.A.
JohnRR
U.S.S.A.
Many people have, I have to run a stock cover so that is how I plan to do it , weld a spacer to the back of the waterpump housing .
