Page 6 of 12 1 2 4 5 6 7 8 11 12
Re: vibration update on the cuda [Re: flatiron] #126964
10/01/08 08:09 AM
10/01/08 08:09 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Put a 2.74 gear in it and you won't reach the MPH necessary to cause vibration . I agree with many other that it sounds like pinion angle to me, Do as suggested and check to make sure the spring perchs are good and not cracked form housing. Could still be a balance problem with the engine somehow. If the B+M flexplate is supposed to be balanced for 360 and the converter people no the converter is going in a 360. The converter may not be neutral balanced and could also be balanced for 360. I would think if both these items were balanced for 360 you would get an out of balance effect.
Re: vibration update on the cuda [Re: flatiron] #126965
10/01/08 08:48 AM
10/01/08 08:48 AM
PA USA
flatiron Offline
flatiron  Offline
PA USA
I would think your next step would be to take the
d-shaft out and put a slip yoke in the trans and
mount something to to keep it from falling out.
Spin it up to the known problem rpm/speed and see
if its still there, that would emininate the d-shaft
and rear end if its still there..... or it would
say that its a d-shaft or rear end problem if it
isnt there
I'm having the same problem and I was wondering about doing this. But I have 2 questions How would you keep the slip yoke on the tailshaft? Will it hurt the engine/tranny running it up to 5500 with no load on it?
Re: vibration update on the cuda [Re: flatiron] #126966
10/01/08 09:05 AM
10/01/08 09:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What I would do is have the car on stands and yoke
in the trans put a jack stand or something like it
with a flat plate mounted to the stand. Slide the
stand in behind the yoke just so its not touching,
so the yoke can move some. Run the car to the speed/rpm
thats the problem point.At least at this point you
could say its there(vib) and know that its a trans/engine
issue or no the vib issnt there and that would say
that its a d-shaft rear end problem. Running the
engine and trans isnt a problem with no load but
when you slow it down put it in N and shut the engine
off, dont put it in park with the engine running
Re: vibration update on the cuda [Re: MR_P_BODY] #126967
10/01/08 01:00 PM
10/01/08 01:00 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Yes for what its worth my Challenger still has the problem. I haven't seen this question asked. What happens if it is put into nuetral above the vibration speed and is allowed to coast back down thru the vibration speed? Mine still shakes regardless if its in neutral or the clutch is disengaged. I was going to try engine off in neutral so the counter shaft and input shaft would not spin. The car is currently in storage.
An engine vibration doesn't have to have the vehicle moving to show up. That would eliminate from the convertor forward if it does not happen with the car at rest. Did I miss something? also when I installed a 2.76 chuck the vibration speed went over 100 mph.
Doug
Re: vibration update on the cuda [Re: dvw] #126968
10/01/08 05:38 PM
10/01/08 05:38 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
had the car out yesterday at around 60pmh, and i could feel it, i put the car in neutral and the vibes were still there until it slowed down below 40. now if i go out on the highway get it up to where its real bad, shut the engine off and coast, if it still has the vibes , im guessing it wouldnt be from the motor right?
Post deleted by Defbob [Re: cudadan] #126969
10/01/08 06:05 PM
10/01/08 06:05 PM
Re: vibration update on the cuda #126970
10/01/08 06:13 PM
10/01/08 06:13 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
It has to be the drive shaft that is why it moved up in speed when you changed to the cruiser rear gear. The yokes may be slightly out of align. I would put a whole different drive shaft in it.
Its not the engine or you could bring the engine up to the rpm it vibrates at setting still and you would feel it. Its the drive shaft.
Getting old just means you were smarter than some and luckier than others.
Re: vibration update on the cuda [Re: dannysbee] #126971
10/01/08 06:16 PM
10/01/08 06:16 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
just a vibration noise thats it. My brain is so fried right now Fred LOL. i'n gonna send the D/s thats in my car to the shop and see if its in specs, i've tried 3 and cant imagine they were all bad, but i wanna know for sure
Re: vibration update on the cuda [Re: wheelsup68dart] #126972
10/01/08 06:47 PM
10/01/08 06:47 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
just had the conveter redone to zero balance
Re: vibration update on the cuda [Re: cudadan] #126973
10/01/08 07:05 PM
10/01/08 07:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Ok Dan, get you a tow strap. Remove the driveshaft, tie strap to car, tie other end to truck. Have someone drive you up to speed and see if the vibe is still there. If its still there continue to tow the car to the highest point possible and push it off(be sure to unhook from truck) LOL j/k.
I hate vibrations, my jeep is double the fun as it has two driveshafts with double cardan joints, so 6 u-joints and 2 slips yokes spinning at all times can be fun when you get a vibe.
68 Barracuda Formula S 340
Re: vibration update on the cuda [Re: cudadan] #126974
10/01/08 07:19 PM
10/01/08 07:19 PM
Columbus, Ohio
Columbus, Ohio
Had it redone to zero balance?????? So it was a 360 balanced converter b4?? I agree with Fred, seldom do I read old threads form the beginning but I did this one and my Brain hurts. I agree with removing the driveshaft and towing it behind another vehicle. My continued thought at this point is pinion angle or broken spring perch. Please advise all on the board how you are adjusting/reading your current pinion angle and what the current reading is.
Re: vibration update on the cuda [Re: Bad340fish] #126975
10/01/08 07:20 PM
10/01/08 07:20 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
LOL i was thinking of a car dolly, but i'd be real affraid to go that fast LOL.
Re: vibration update on the cuda [Re: cudadan] #126976
10/01/08 07:44 PM
10/01/08 07:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if you dont want to drag it that fast you
better do what I suggested on the stands, either
way it would eliminate alot of stuff and zero in
on the problem
Re: vibration update on the cuda [Re: MR_P_BODY] #126977
10/01/08 07:46 PM
10/01/08 07:46 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
on the problem
im gonna try that first cause its easier lol
Post deleted by Defbob [Re: cudadan] #126978
10/01/08 07:59 PM
10/01/08 07:59 PM
Re: vibration update on the cuda #126979
10/01/08 08:44 PM
10/01/08 08:44 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
LOL i dont wanna jinx anybody with this
Re: vibration update on the cuda [Re: cudadan] #126980
10/01/08 08:44 PM
10/01/08 08:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
How are you sintalling teh u joints? Are you seating them against the clips after installing the clips? It's driveshaft. Definately. If you moved it up and fdowna couple degrees (pinion angle) what is is currently set at? You are positive you're measuring it properly?
im using a vise to put them in and pushing them up against the clips too.
There are 4 clips to align the u joint 2 that retain the joint in the shaft.
And 2 that position the joint in the pinion yoke. Some people discard these, do you still have yours? They are needed as they properly position/align the joint into the pinion yoke.
You also stated you did Not replace the crush sleeve when you did the gear change. If you grab the pinion yoke can you force any up or down play out of it, or is it tight.
On the front yoke you stated you had plenty of clearence. How much is plenty, if you have to much that can cause vibration too. After bottoming out the slip yoke I like about 1/2 to 3/4 of a inch clearence. 1" would be max IMO
Also what happend with you putting that thing on stands and running with no shaft and a slip yoke plug. On sunday you said that was a great idea and would try that.
But today you take it out for another cruise only to confirm the vibration, again!!
I too think its related to the shaft or its componets. When you did the shaft run out was it installed on the car or on v blocks.
You will get her figured out, because you have alot heads working on it . mike
Re: vibration update on the cuda [Re: Sport440] #126981
10/01/08 08:54 PM
10/01/08 08:54 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
i do have the clips in the ujoint all the way around, i have a max of 3/4 clearance, i didnt get a chance to spin it on the stands with just the yoke in the tail shaft cause i had to work. im gonna do my best to try it tomorrow after work, cause friday,sat and sun i'll be camping in the pocono's lol
Re: vibration update on the cuda [Re: MR_P_BODY] #126982
10/03/08 08:49 AM
10/03/08 08:49 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
im gonna give this a shot when i get back on sunday, i'll let you guys know what happens,
thx again for the replys guys
Post deleted by Defbob [Re: cudadan] #126983
10/03/08 08:51 AM
10/03/08 08:51 AM
