Re: vibration update on the cuda
[Re: flatiron]
#126965
10/01/08 08:48 AM
10/01/08 08:48 AM
Posts: 724 PA USA
flatiron
PA USA
I would think your next step would be to take the d-shaft out and put a slip yoke in the trans and mount something to to keep it from falling out. Spin it up to the known problem rpm/speed and see if its still there, that would emininate the d-shaft and rear end if its still there..... or it would say that its a d-shaft or rear end problem if it isnt there
I'm having the same problem and I was wondering about doing this. But I have 2 questions How would you keep the slip yoke on the tailshaft? Will it hurt the engine/tranny running it up to 5500 with no load on it?
Post deleted by Defbob
[Re: cudadan]
#126969
10/01/08 06:05 PM
10/01/08 06:05 PM
#126970
10/01/08 06:13 PM
10/01/08 06:13 PM
Posts: 5,160 Texas
dannysbee
Texas
It has to be the drive shaft that is why it moved up in speed when you changed to the cruiser rear gear. The yokes may be slightly out of align. I would put a whole different drive shaft in it.
Its not the engine or you could bring the engine up to the rpm it vibrates at setting still and you would feel it. Its the drive shaft.
Getting old just means you were smarter than some and luckier than others.
[Re: wheelsup68dart]
#126972
10/01/08 06:47 PM
10/01/08 06:47 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
Put a 2.74 gear in it and you won't reach the MPH necessary to cause vibration . I agree with many other that it sounds like pinion angle to me, Do as suggested and check to make sure the spring perchs are good and not cracked form housing. Could still be a balance problem with the engine somehow. If the B+M flexplate is supposed to be balanced for 360 and the converter people no the converter is going in a 360. The converter may not be neutral balanced and could also be balanced for 360. I would think if both these items were balanced for 360 you would get an out of balance effect.
just had the conveter redone to zero balance
[Re: cudadan]
#126973
10/01/08 07:05 PM
10/01/08 07:05 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Ok Dan, get you a tow strap. Remove the driveshaft, tie strap to car, tie other end to truck. Have someone drive you up to speed and see if the vibe is still there. If its still there continue to tow the car to the highest point possible and push it off(be sure to unhook from truck) LOL j/k.
I hate vibrations, my jeep is double the fun as it has two driveshafts with double cardan joints, so 6 u-joints and 2 slips yokes spinning at all times can be fun when you get a vibe.
68 Barracuda Formula S 340
[Re: cudadan]
#126974
10/01/08 07:19 PM
10/01/08 07:19 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
Had it redone to zero balance?????? So it was a 360 balanced converter b4?? I agree with Fred, seldom do I read old threads form the beginning but I did this one and my Brain hurts. I agree with removing the driveshaft and towing it behind another vehicle. My continued thought at this point is pinion angle or broken spring perch. Please advise all on the board how you are adjusting/reading your current pinion angle and what the current reading is.
[Re: Bad340fish]
#126975
10/01/08 07:20 PM
10/01/08 07:20 PM
cudadan
Stratford nj
LOL i was thinking of a car dolly, but i'd be real affraid to go that fast LOL.
[Re: MR_P_BODY]
#126977
10/01/08 07:46 PM
10/01/08 07:46 PM
cudadan
Stratford nj
Well if you dont want to drag it that fast you better do what I suggested on the stands, either way it would eliminate alot of stuff and zero in on the problem
im gonna try that first cause its easier lol
[Re: cudadan]
#126978
10/01/08 07:59 PM
10/01/08 07:59 PM
[Re: cudadan]
#126980
10/01/08 08:44 PM
10/01/08 08:44 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
How are you sintalling teh u joints? Are you seating them against the clips after installing the clips? It's driveshaft. Definately. If you moved it up and fdowna couple degrees (pinion angle) what is is currently set at? You are positive you're measuring it properly?
im using a vise to put them in and pushing them up against the clips too.
There are 4 clips to align the u joint 2 that retain the joint in the shaft.
And 2 that position the joint in the pinion yoke. Some people discard these, do you still have yours? They are needed as they properly position/align the joint into the pinion yoke.
You also stated you did Not replace the crush sleeve when you did the gear change. If you grab the pinion yoke can you force any up or down play out of it, or is it tight.
On the front yoke you stated you had plenty of clearence. How much is plenty, if you have to much that can cause vibration too. After bottoming out the slip yoke I like about 1/2 to 3/4 of a inch clearence. 1" would be max IMO
Also what happend with you putting that thing on stands and running with no shaft and a slip yoke plug. On sunday you said that was a great idea and would try that.
But today you take it out for another cruise only to confirm the vibration, again!!
I too think its related to the shaft or its componets. When you did the shaft run out was it installed on the car or on v blocks.
You will get her figured out, because you have alot heads working on it . mike
[Re: Sport440]
#126981
10/01/08 08:54 PM
10/01/08 08:54 PM
cudadan
Stratford nj
i do have the clips in the ujoint all the way around, i have a max of 3/4 clearance, i didnt get a chance to spin it on the stands with just the yoke in the tail shaft cause i had to work. im gonna do my best to try it tomorrow after work, cause friday,sat and sun i'll be camping in the pocono's lol
[Re: MR_P_BODY]
#126982
10/03/08 08:49 AM
10/03/08 08:49 AM
cudadan
Stratford nj
What I would do is have the car on stands and yoke in the trans put a jack stand or something like it with a flat plate mounted to the stand. Slide the stand in behind the yoke just so its not touching, so the yoke can move some. Run the car to the speed/rpm thats the problem point.At least at this point you could say its there(vib) and know that its a trans/engine issue or no the vib issnt there and that would say that its a d-shaft rear end problem. Running the engine and trans isnt a problem with no load but when you slow it down put it in N and shut the engine off, dont put it in park with the engine running
im gonna give this a shot when i get back on sunday, i'll let you guys know what happens,
thx again for the replys guys
[Re: cudadan]
#126983
10/03/08 08:51 AM
10/03/08 08:51 AM
