rearend...small to large bolt pattern #1268698
07/16/12 11:45 AM
07/16/12 11:45 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
72 Demon ,original 340 car with 8 3/4 rearend but smallbolt pattern. Looking to buy axels with largebolt and will need different rear drums. Anyone know what source or part number ?? Napa usually is good with drums on old iron. Thanks to all in advance
Re: rearend...small to large bolt pattern [Re: terzmo] #1268699
07/16/12 12:39 PM
07/16/12 12:39 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I used Moser with b-body brake spacing but they do use green bearings.
-Daty
Re: rearend...small to large bolt pattern [Re: terzmo] #1268700
07/16/12 01:53 PM
07/16/12 01:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You either have to change over to B/E brakes including backing plates or get Axles that have A body offset but with LBP center register and then try to find an obsolete pair of drums .
I was supposed to check out one of these mythical drums but yet to have the time to do it due to busty work schedule.
Re: rearend...small to large bolt pattern [Re: JohnRR] #1268701
07/16/12 02:02 PM
07/16/12 02:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I want you schedule...
Re: rearend...small to large bolt pattern [Re: 1_WILD_RT] #1268702
07/16/12 02:08 PM
07/16/12 02:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Or get BBP axles with A body SBP offset/register and drill the SBP drums to large.
The axle # to use SBP drums redrilled to large:
A30-CST-A45
Re: rearend...small to large bolt pattern [Re: JohnRR] #1268703
07/16/12 03:04 PM
07/16/12 03:04 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
so by just buying stock A body 30 spline axels with large bolt pattern and green bearings; I have to also change brakes and drums ?? (nothing easy)
Re: rearend...small to large bolt pattern [Re: terzmo] #1268704
07/16/12 03:15 PM
07/16/12 03:15 PM
I have had several sets of small pattern axles drilled and tapped for the larger(4.5 on 5) bolt patterns several times We used the Moroso or Mr Gasket 3x1/2x20 screw in studs, make sure and spot weld them on the back sides of the axles also Have the same machine shop drill the stock brake drums for the large bolt pattern also If you want after market axles you can have them custom made for the stock rear brakes and have the stock brake drums center machined out to fit the larger big bolt pattern axles center register, you will also need to have the axle flange diameter cut down to use on the small bolt pattern brake drums, or swith it over to a set of the larger bolt pattern brakes, drums and backing plates with the larger axle spacing between the axle and brake drum spacing
Re: rearend...small to large bolt pattern [Re: terzmo] #1268705
07/16/12 03:19 PM
07/16/12 03:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Redrill your current drums, as said, as long as as the axles have the small bolt pattern register.
And you have to SPECIFIY small bolt offset and register so you don't get the wrong axles that require changing the brakes.
Re: rearend...small to large bolt pattern [Re: JohnRR] #1268706
07/16/12 06:16 PM
07/16/12 06:16 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You're better off upgrading to LBP brakes. Tons of them in the U-Pull-It yards. New 10"x1.75" SBP drums are scarce, 10"x2" LBP drums are common.
Re: rearend...small to large bolt pattern [Re: B5 Bee] #1268707
07/16/12 06:43 PM
07/16/12 06:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Probably the best thing to do , the drums I'm speaking of, if still can be had thru a source I found, were priced at $300 each.
I have 2 new pairs of the small bolt pattern drums so I'm all set.
