302 heads vs 67 closed chamber heads on 318?
#1268608
07/16/12 01:46 AM
07/16/12 01:46 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I understand that 1967 was the sole year (or close to it) that 318s had closed-chamber heads until the 302 head came along later in the 80s.
My engine just rolled over 107,000 miles - I know that the valve guides are a little wobbly from when I changed the springs, and had use or not I'm sure the valve seats have seen better days (stem heights appeared equal but who knows what the actual sealing surface looks like).
I found Clearwater Cylinder Heads on eBay selling refurbed 302 castings for about $185 a pop, including valves. 68-72cc chambers. Supposedly there are some suppliers out there like CM Engines who sell for even less if you ask (this is according to a 4 year old post, though).
What'd be better worth my money - buying a pair of new 302 heads for around $400-500, or having my existing heads refurbed for that much or more? I don't know many machine shops around here nor what $500 would buy in good head work beyond guides/seats, or if 67s are worth messing with. Of course there's the wildcard 360 head but I still don't understand if it's possible to recover the lost compression on those with head milling alone.
There's a bazillion articles and posts and topics about 302s, but I haven't been able to find out much about the original '67 small block heads.
Inform me, please!
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 302 heads vs 67 closed chamber heads on 318?
[Re: Secret Chimp]
#1268609
07/16/12 03:17 AM
07/16/12 03:17 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Id buy the 302s, they are swirl port design and will flow a lot better..
I am truckless..
[Re: Dean_Kuzluzski]
#1268611
07/16/12 06:57 AM
07/16/12 06:57 AM
Posts: 15,487 Florida
scratchnfotraction
67 = non hardend valve seats if you are going to buy heads have you thought about the mag heads with LA intake bolt pattern? EQ-heads IIRC and about the same price. closed chambers,bigger valves,better port flow for untouched heads. myself i like a 360 head on a 318 and shave .050 off for a CR bump,mild cam and lots more breathing on top end. I did like the #302 head when I home pocket port and bump valves to 1.88/1.60 but still prefer the 360 heads over all. the last set of #302 heads I just pocket ported the exhast side and bumped the valve to a 1.60 for a 1.78/1.60 valve set.
[Re: scratchnfotraction]
#1268612
07/16/12 12:38 PM
07/16/12 12:38 PM
Secret Chimp
Eugene, Oregon
Would those LA-Magnum heads require anything beyond different pushrods?
[Re: Secret Chimp]
#1268613
07/16/12 02:48 PM
07/16/12 02:48 PM
scratchnfotraction
on a non roller cam LA engine...yes it is a magnum head with a LA intake bolt angle change.
it will need oil thru lifters/PRs to oil the magnum rocker gear.
this is why I like a pre-magnum roller cam LA engine, it has oil thru roller lifter/hollow PRs and oils like an older LA engine thru the head to the shaft rockers.
oiling both ways I would have thought it would have to much oil in the VC but not the case. most 90-93 318/#302 heads do it this way stock.
so I would be able to swap a set of mag heads right on with the stock magnum PR and have the older LD340 intake on it for a pre-mag hybrid 318.
#1268614
07/16/12 05:13 PM
07/16/12 05:13 PM
Secret Chimp
Eugene, Oregon
Interesting. I didn't know you could get new/fresh-refurbed Magnum heads set up for use on LAs like that. I'd only heard of people buying used heads and then having them redrilled for the LA intake bolt angle during a normal refurb.
But still it sounds like I'd have to buy both the heads and a Magnum roller valvetrain for like another $300 from Comp or someone, right? It doesn't sound like my shaft-oil rockers on my current heads would transfer.
[Re: Secret Chimp]
#1268615
07/16/12 06:02 PM
07/16/12 06:02 PM
scratchnfotraction
correct,they will use the magnum pedistal mount 1.6 rockers and need the PR oiling. the magnum rocker/pedistals are fairly cheap for a full set at the dealer IIRC around 60$ for 16. I have a few complete sets of roller valve gear from junking stuff.PM me if you need something for stock roller valve gear. I am working on getting a set of the EQ heads for a hybrid build. I am stroking the 88-318 with a 360 crank for a 349 stroker with magnum heads/LD340 intake and voodoo roller cam
