Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: moparpollack]
#1267639
12/31/14 12:09 AM
12/31/14 12:09 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
How's that 273 running?
Good question. I'll let you know as soon as I know.
[Re: MuuMuu101]
#1267641
02/01/15 12:48 AM
02/01/15 12:48 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So today I decided to stop thinking about the things that are stressing me out more in life and focus on a different, but arguably, less burdensome task. I finished putting together the entire front suspension and brake setup. I toqued everything but I haven't fiddled with my camber bolts because I'm not sure how to set those properly. I also installed my Hotchkis, Fox Adjustable shocks and right now I set them to the softest setting. I just hope when I start driving this thing it will be painless and I won't find things I overlooked or forgot. Right now, what I need to do is remake a couple of the front brakelines to make up for the front mounted calipers, swap out my rear shocks, install subframe connectors and sway bars, send it to an alignment shop, and some fluid based maintenance (oil change, add trans fluid, flush radiator, etc.)
[Re: MuuMuu101]
#1267643
02/15/15 02:54 AM
02/15/15 02:54 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I know it's towards the end, but I'm throwing in the towel. I've got the wheels on the car and put the car on the ground. Definitely an awesome moment and all I could think was how bad @$$ it was. Well, next weekend, I'm going to be sending the car over to my mechanics. I'm going to have them redo a couple brake lines, do some regular maintenance, set its alignment, and weld in the sway bars and subframe connectors.
Hopefully it will be done sometime before April and I'll be able to take it to the Hotchkis Autocross and/or Spring Fling.
One thing I was upset about was that one side sits higher than the other. Whenever I fiddled with the passenger side adjuster the ride height changed. No matter how much I tightened or loosened the driver side torsion bar adjuster the ride height stayed the same so now my car has a little gangster lean to it. The whole driver side is taller than the passenger side. Overall, I like the ride height of the passenger side.
Also, it looks like there may be some interference with the top passenger quarter panel brace. I don't have that problem with the driver's side because the brace tore off sometime in its lifetime... No, seriously, the mounting points are gone, sheared.
Due to the wheels, the GT trim is starting to grow on me. I really don't know why, but not too long ago I wanted to throw it all out. Now I wish I kind of had the driver's door trim and all the trim was in better condition.
So here are some pictures... I edited on my phone, increasing the brightness and adding a filter to see more of the details. That's why there's an interesting hue to it.
Driver's side:
[Re: MuuMuu101]
#1267644
02/15/15 02:55 AM
02/15/15 02:55 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1267645
02/15/15 02:55 AM
02/15/15 02:55 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1267646
02/15/15 02:56 AM
02/15/15 02:56 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1267647
02/15/15 02:56 AM
02/15/15 02:56 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1267648
02/15/15 02:57 AM
02/15/15 02:57 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: RUNCHARGER]
#1267651
02/15/15 04:33 PM
02/15/15 04:33 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
That's looking nice. Strangely I like the trim as well. It sets it off and actually works well with the new wheels.
Sheldon
Just a week ago I wanted to completely get rid of it, now I'm not so sure anymore. Like I said, I kind of wished I had a driver's door trim. Ironically, someone a year or two ago on FABO was selling one and someone informed me of it. I blew it off because I was planning on removing it some day. Now I kind of wish I didn't.
[Re: MuuMuu101]
#1799750
04/09/15 09:30 PM
04/09/15 09:30 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Well, a big update for you guys... I got the Dart on all 4's again and sent it to a shop. Part of it is to get some safety concerns addressed and the other part is to make it a racecar. Things on the list to get done... Engine swap (I already have a deal made it should make more than enough power for me to handle), new steering box (we're going to try something new, not Borgeson or FirmFeel), a potential manual trans swap (up in the air), and new interior (seats, belt, steering wheel, steering column/maybe, and a 4-point cage). It should be fun, but man is it going to hurt the bank account.
Before it left today.
[Re: MuuMuu101]
#1799821
04/09/15 10:38 PM
04/09/15 10:38 PM
moparpollack
Lil Herman
Lil Herman
85086
Nice Mustang!
