Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#1267279
07/27/12 10:20 AM
07/27/12 10:20 AM
moparpollack
Lil Herman
Lil Herman
85086
You are missing a ground on your dash circuit. Do the dash lights work? Time to fix the cheap and simples that go a long way.
[Re: MuuMuu101]
#1267280
07/27/12 11:09 AM
07/27/12 11:09 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
This is the shady work I am talking about...
I like the road trip idea!
[Re: moparpollack]
#1267281
07/27/12 12:13 PM
07/27/12 12:13 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I really haven't been in my car at night, but from what I remember 2 weeks ago showing the car to my friend that the dash light was working (behind the speedo at least). I don't recall/know if any of the other dash lights work.
[Re: RSNOMO]
#1267287
07/29/12 02:51 PM
07/29/12 02:51 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I'd go easy on the E-brake...After all these years, it's probably less than ideal...
No need with an auto trans...
Unless yer planning on some 'slalom' driving...
I don't use the E-Brake for driving uses. I use it for parking uses and forget to take it off before I drive.
[Re: NV69B7RR]
#1267289
07/30/12 12:50 AM
07/30/12 12:50 AM
moparpollack
Lil Herman
Lil Herman
85086
Power steering fluid +motor mount rubber =
[Re: DynoDave]
#1267291
07/30/12 01:14 AM
07/30/12 01:14 AM
moparpollack
Lil Herman
Lil Herman
85086
Time to get out the grinder and cut that mess off . Other than that mess is the column fine?
[Re: wally426ci]
#1267295
08/01/12 10:28 AM
08/01/12 10:28 AM
moparpollack
Lil Herman
Lil Herman
85086
I personally think I would stop driving it and go over the thing with new belts and hoses, as well as new brake parts with all cylinders. If you keep setting that damn parking brake it is liable to get stuck on. I don't know anyone with an old car that uses it on an auto trans.
I agree that replacing the hydraulics in the brakes is cheap and easy. Plus you would get to play with brake springs for the first time.
[Re: moparpollack]
#1267296
08/01/12 12:44 PM
08/01/12 12:44 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I want to drive it to the cruise tomorrow and to Garden Grove on Friday and wait till the weekend before I start getting into it. So a parking brake really isn't needed when parked with an auto? If I'm going to replace brake stuff I might as well find a legit floor jack on CL and buy one this weekend. And wouldn't I need a brake bleeder as well if I'm going to be replacing the cylinders? Where would I buy one, Harbor Freight (not too big of a fan of theirs)?
[Re: MuuMuu101]
#1267297
08/01/12 01:25 PM
08/01/12 01:25 PM
moparpollack
Lil Herman
Lil Herman
85086
Don't need a bleeder if you have a friend. Do you have a friend to help? If you don't have a one man bleeder from harbor freight is $5. So skip lunch or eat top ramen and buy a kit.
[Re: moparpollack]
#1267298
08/01/12 01:34 PM
08/01/12 01:34 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
OzHemi is my friend... I think... I can spend like $20-25 on a better bleeder if there's one available. Again, I'm not too big a fan of Harbor Freight. You think a 2 ton floor jack would be sufficient or should I go for 2 1/2 tons? Also going to look for some jack stands. I can find cheap ones on CL and buy it tomorrow or Saturday.
