A body w/s washer tank #1266947
07/13/12 01:56 PM
07/13/12 01:56 PM
Neenah,Wi
rod440 Offline OP
rod440  Offline OP
Neenah,Wi
A while back I purchased a repo washer resivior for a '72 A body,when compared to the original tank it's about a 1/4" shorter,including the center distance of the mounting holes.I could slot the mounting holes to make it fit but the flat washers would hang over the edge of the mounting tabs & look like %^&*! Are all the repo tanks like this,is there more than one company that actually makes them? It has a Mopar approved reproduction part sticker on it,if that means anything.Has anyone had this problem?
Re: A body w/s washer tank [Re: rod440] #1266948
07/13/12 02:11 PM
07/13/12 02:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I had the same problem wit ha 68-70 B body tank , I ended up drilling a new hole to mount it as I was in a pinch
