Page 3 of 3 1 2 3
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: 67coronetman] #1265130
07/12/12 09:05 AM
07/12/12 09:05 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Does the OP realize that a higher compression engine, well designed with a proper cam and quench will not detonate as much as a similar one with less Compression and less quench?
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: DJVCuda] #1265131
07/12/12 09:40 AM
07/12/12 09:40 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Further, does the OP realize it takes a considerably bigger camshaft (with quite a bit more duration than Hughes specified) to make a 500ci engine idle "super lopey"?
Rich H.
Esse Quam Videri
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: ZIPPY] #1265132
07/12/12 09:45 AM
07/12/12 09:45 AM
Holly/MI
Dean_Kuzluzski Online content
Dean_Kuzluzski  Online Content
Holly/MI
Maybe he wants it so mild that everyone thinks it still has a slanty 6'er in there!!
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: ZIPPY] #1265133
07/12/12 09:46 AM
07/12/12 09:46 AM
tboomer Offline
tboomer  Offline
I am thinking that the op should just build what he has... I don't think Kevin is steering him in the wrong direction. He treated me well and I only bought some trinkets from them. I am gonna call him later today about some parts. Good luck with what you decide to do!
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: tboomer] #1265134
07/12/12 03:10 PM
07/12/12 03:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
To many peas in the pot. We see it all the time on here. The OP needs to decide who is building the eng that he trust and go with that info. There are many ways to get what he wants and it seems he is getting about 20 different opinions here to confuse it even more. Decide on the one you will trust and go with that. That said I have bought some parts from Hughes for my 493 I built and they treated me great. Good service and fast delivery. Good luck to you. Ron
Re: 4.15 stroke vs 4.25 stroke what are the pros and cons [Re: torqueaddict] #1265135
07/13/12 09:24 AM
07/13/12 09:24 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
go with the 4.15 stroke i have done 3 of them now
and they are very reliable and rev all day long
one with 915 heads 2.14 8.18 valves comp hyd cam rpm 440 850 demon made 450hp @ 5000 and 550 tq @3000 small cam
one with rpm heads 6pk solid roller made 600 hp @6000 600tq @ 4000
one with victor heads solid roller indy dp 1000 cfm hp carb that i have not fired yet
the 4.15 is a true street strip combo that works good
if it aint broke don't fix it
Page 3 of 3 1 2 3
