Re: Porpoising
[Re: turner]
#1264907
07/09/12 09:09 PM
07/09/12 09:09 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Re: Porpoising
[Re: turner]
#1264909
07/09/12 09:21 PM
07/09/12 09:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
2 things can cause this... tire pressure real high and shocks... and in some cases its both... you will need to get adjustable shocks... you can do a band-aid and lower the tire pressure BUT it might get loose on the top end..... oh... I'm not a fan of snubbers... they were made to a crutch for worn out springs
Re: Porpoising
[Re: turner]
#1264911
07/09/12 09:48 PM
07/09/12 09:48 PM
MR_P_BODY
Ive got some video showing it, how do I post it?
If its a you tube just copy and paste it... a vid from your comp.... no clue(I'm no comp guy)
Re: Porpoising
[Re: MR_P_BODY]
#1264912
07/09/12 10:15 PM
07/09/12 10:15 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
also you could be bottoming out the shock.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
Re: Porpoising
[Re: turner]
#1264920
07/09/12 11:33 PM
07/09/12 11:33 PM
MR_P_BODY
I think most of your problem is in the front end... you need more travel EDIT Like I said before... I'm not a fan of those CE shocks... the Caltrac fronts seem to work on most cars for a cheapo shock
Re: Porpoising
[Re: MR_P_BODY]
#1264922
07/10/12 04:29 AM
07/10/12 04:29 AM
Posts: 660 San Diego
formula S
San Diego
Re: Porpoising
[Re: turner]
#1264924
07/10/12 01:10 PM
07/10/12 01:10 PM
Posts: 5,895 Florida
Locomotion
I tried Mopar auto drag shocks on the rear with SS springs on my car a long time ago and it would wheel-hop under certain conditions. I switched to Rancho shocks and never wheelhopped again. Harder leaving, higher HP cars seem to need stiffer shocks. Of course it would spin occasionally depending on track conditions, but it spun "smoothly". Rear shocks have to control the winding up and unwinding of the leaf springs and the regular shocks couldn't. But working on the front end should help also. I found OEM style shocks tended to raise the front end too quickly and compressed too easily. Koni adjustable drag shocks are on mine now. But you have a big block which makes transfering the extra weight that's on the nose and keeping it transferred more difficult.
It was a totally different set-up, home built chassis with ladder bars, but I found that adding 100+ lbs in the trunk of my old bracket Challeneger helped it be much more consistent.
Re: Porpoising
[Re: turner]
#1264925
07/10/12 01:19 PM
07/10/12 01:19 PM
Posts: 304 Maryland
SLEDGEHAMMER
Maryland
I had the same thing happen years ago with my Dart and it turned out the shocks were worn out. Once I replaced them the porpoising was gone.
1971 Dodge Dart - Powerplant <<TBD>>
