Clutch Fork - What is the elongated hole for? #1264812
07/09/12 05:09 PM
07/09/12 05:09 PM
Colorado
CuriousYella70 Offline OP
Colorado
I've seen two different types of clutch forks. One with just a single hole and a small crease where your spring goes and another that has the clutch rod hole on the end with an elongated hole - why are their two types of forks?
Re: Clutch Fork - What is the elongated hole for? [Re: CuriousYella70] #1264813
07/09/12 06:25 PM
07/09/12 06:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The elongated hole is to make it easier to get the hooked end of the spring in the fork.
