Re: crower lifter
[Re: bigbee]
#1264669
07/09/12 12:21 PM
07/09/12 12:21 PM
Posts: 6,295 U.S.
moparniac
U.S.
I was gonna buy a set of crowers but the hole placement was right in line with the lifter bushing hole in my block which would give to much oil up top...
Mopar Performance
Re: crower lifter
[Re: bigbee]
#1264670
07/09/12 12:34 PM
07/09/12 12:34 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
The notches don't matter, there probally for a .903 diameter Chevy type oiling, one body, many applications The pushrod hole is in the proper locatiion to intersect the main stock lifter oil passage When in doubt call Crower BTW, is your block bushed in the lifter bores or still stock? If bushed check the oiling hole location in the oil galley side to make sure it is there If bushed and there not there you will need them to oil the pushrods If not bushed, your good
Re: crower lifter
[Re: bigbee]
#1264671
07/09/12 01:02 PM
07/09/12 01:02 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Crower says that the pushrod oiling hole must not intersect the oil galley directly
This is correct. The oil is fed from the clearance around the lifter in the bore. This results in no pressure loss since the oil would normally seep out the top or bottom of the bores anyway.
You may want to consider the Crane 66550. And "competitionwedge" is your man for those!
Re: crower lifter
[Re: bigbee]
#1264675
07/10/12 11:29 AM
07/10/12 11:29 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The point being can I safely eliminate them?
Eliminate what, the notches? How?
Again, what's the lift of your cam?
Re: crower lifter
[Re: Stanton]
#1264676
07/13/12 10:13 AM
07/13/12 10:13 AM
bigbee
Thanks for your response.
Cam lift approx .500, valve lift is .800. I was trying to get Crower to eliminate the operation for the notches, but I have been unsuccessful. Now it seems they don't have anything that will work. I really want to try their Enduramax lifter. So I guess I'll bush the lifter bores.
Now there is a whole new set of questions. I have an aluminum block hemi and the cylinder deck is covered in a way that prevents the lifter from going into the bore if it is too high. But I need to extend the bore to cover any oil holes or notches. The only lifter for which I have any dimensions is the one I showed you that you said looks like your Crane.
I'm not completely certain how that lifter works. Have you used yours yet? My concern is that if an oil band lifter has the pushrod oiling hole only about .030 above the band and the HIPPO (high pressure pin oiling) in the band, will the notched style work as well? I have a banded set now, but the oiling hole comes out of the bore. I've heard stories about guys with the oil band lifters, putting a very small groove between the band and the oil hole for the oil to follow because they were not getting enough up top. Now with this notched type, the oiling holes are much further away. Need to hear from someone. And Crower says they can't help? I have also heard that Crower don't care much for the Mopar bunch. They are happy just dealing with the much bigger everyday Chevy or Ford crowd.
But anyway, if I'm getting my lifters bushed, it is recommended that I put a little .045 hole in the bushing to feed each lifter. That part, I am OK with, but this lifter without an oil band, I don't know. Is the combination of the bushing and this lifter going to be a problem? Any advice?
