2.7 engine timing chain question #1263309
07/06/12 11:00 PM
07/06/12 11:00 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I'm replacing the timing chain on my wifes 2001 2.7 sebring. I got an aftermarket chain set. None of the links are plated to set up the timing chain. Could someone let me know how many links from the crank mark up to the left gear(double gold links) . and then over to the right side.
What I have to do is count them out and mark them with paint. Thanks Mike
Re: 2.7 engine timing chain question [Re: moparmikethree] #1263310
07/07/12 01:10 AM
07/07/12 01:10 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
There's a website that I went on when I had a bunch of 2.7 's to work on that have the timing mark alignment,shows the links & gives the number links between the marks. I googled. "2001 Chrysler 2.7 timing marks &after looking at couple websites I found it
