1967 Steel Wheel 14x5.5 ? #1263044
07/06/12 03:02 PM
07/06/12 03:02 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Going trough my junk and found a set of these 14x5.5 (LBP)wheels. Can't remember if there off my old 67'383 wagon or r/t or neither. Back space looks to be 3.750", center hole is about 2.8" all that is by stem is five on one side and five and one on the other side. Might be early 68' as the wagon was late 67' Any ideas ? Thanks
Re: 1967 Steel Wheel 14x5.5 ? [Re: Beebuzzn] #1263045
07/06/12 03:04 PM
07/06/12 03:04 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Picture of wheel. Also 67' style large dog dish fits wheel.
Re: 1967 Steel Wheel 14x5.5 ? [Re: Beebuzzn] #1263046
07/07/12 02:05 AM
07/07/12 02:05 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Those look to be correct 67 "Hemi" wheels (all HP 440 and Hemi B-body cars came with those unless ordered with Chrome Road Wheels, all 67 B-body wagons also had them regardless of engine). Later 67 versions had date codes on them (they started adding date codes sometime around March 67). 1966 versions were identical but had an extra hole in between each lug hole.
*Do you have all 5?
Stop the presses! I just noticed the small wheel cover retention nubs on the outer rim areas. Those are not B-body rims, they are the (WAY more common) C-body style.
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263047
07/07/12 01:49 PM
07/07/12 01:49 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Thanks Scott, are the nubs you are talking about the ones by the valve stem ?
Re: 1967 Steel Wheel 14x5.5 ? [Re: Beebuzzn] #1263048
07/07/12 03:32 PM
07/07/12 03:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, you can see one of them a couple inches to the right of the valve stem about even with the cap in your first pic
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263049
07/07/12 07:32 PM
07/07/12 07:32 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Well I found a picture showing some of my old cars including the wagon and it had those wheels on it. I bought the wagon from second owner. He bought when it was a year old from the dodge dealer here in Seattle. They told him it was a lease return. Was a gold car originaly but was painted white sometime before he bought it. Was neat car disc brake, 3:23 suregrip, 383 four barrel and ran strong. Wheels must have been replaced early on.
Re: 1967 Steel Wheel 14x5.5 ? [Re: Beebuzzn] #1263050
07/08/12 02:41 PM
07/08/12 02:41 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Went through some more pictures today and here is one of the 67 r/t looks like the same wheel to me. Hard to see nubs by valve stem in this picture as I had to scan it. But when I upped the resolution looked like they where there. If current owner of car is member here how about a wheel picture ? Car is gold, black painted top, white interior, 4spd console. Thanks
Re: 1967 Steel Wheel 14x5.5 ? [Re: Beebuzzn] #1263051
07/08/12 02:53 PM
07/08/12 02:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The black wheel shown is 100% absalutely possitively an original 1967 14x5.5 B-body "Hemi Wheel". Check out the details. Then look at the next example, a blue painted wheel, which is also a 14x5.5, but NOT a Hemi wheel.
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263052
07/08/12 02:54 PM
07/08/12 02:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#2
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263053
07/08/12 02:55 PM
07/08/12 02:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This one is NOT a Hemi wheel but looks very close to one, as does yours (likely exactly like yours). Do you see an "KH" markings anywhere on yours?
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263054
07/08/12 02:55 PM
07/08/12 02:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
See those little nubs? They are not found on Hemi wheels
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263055
07/08/12 09:36 PM
07/08/12 09:36 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Scott, is the difference B-body vs C-body like on friday, or Hemi vs non Hemi like today? Does a 440 GTX have the same wheel as a hemi R/T, and the same wheel as a 67 B-body wagon? confused.
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263056
07/08/12 10:16 PM
07/08/12 10:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, 67 440/Hemi R/T and GTX, and all 67 (B-body) Wagons used the same 14 x 5.5 wheels.
The only versions they used were the style shown in my example (black wheels) above.
The only possible exception would be the 1966 high performance/wagon B-body versions that could have made it on to a few early build 67s. The 66 wheels look identical to the 67s other than having additional holes between the lug holes.
Any other variations that turn up were used on some other application (C-body, truck, later year application, or other brand like Ford, whatever).
Re: 1967 Steel Wheel 14x5.5 ? [Re: ScottSmith_Harms] #1263057
07/10/12 04:17 PM
07/10/12 04:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Here are some wheels known to be from original 67 B-bodies. This is from a 67 Belvedere II, 383 2bbl, trailer towing, 11' brakes, sway bar 3.23 SG, 14x5.5 wheels, 775x14 tires. all 5 including spare look like this. I have the window sticker. Built in LA.
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263058
07/10/12 04:20 PM
07/10/12 04:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
775 - 14 spare still new
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263059
07/10/12 04:21 PM
07/10/12 04:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
can you post pics of the centers showing the flats between the lug holes in good detail? Do they have date code or manufacturer stampings (such as "KH"?
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263060
07/10/12 04:22 PM
07/10/12 04:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This is from a 67 Belvedere wagon junkyard car. The wheels are body color, beat up small hub caps inside the car, had 2 wheels, one ruined. I have the certicard, unable to locate at this time. It has a stamped KELSEY HAYS in a circle on the inside of the bead. Wont show up in a photo with this camera
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263061
07/10/12 04:23 PM
07/10/12 04:23 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
close up
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263062
07/10/12 04:26 PM
07/10/12 04:26 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This is from a 1967 GTX I bought from the original owner. This was the spare, other 4 wheels MIA. I have fender tag, certi card with his name on it, IBM card. The car was built 9-27 in St Louis.
Re: 1967 Steel Wheel 14x5.5 ? [Re: NANKET] #1263063
07/10/12 04:27 PM
07/10/12 04:27 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
close
